My bandsaw build. Redoing the lift and lower
Started by Kwill, February 27, 2018, 11:14:54 AM
Kbeitz
Most guides have a flange on the back to help hold the blade on if your pushing to hard. Maybe you could tack a large washer to your bearing.
Love machine shop work
and Wood work shop work
And now a saw mill work
starmac
Maybe it is my eyes, but it looks like that idler has a small flange on it, or is that some sort of backing plate i am seeing?
Kwill
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Wudman
Quote from: Kwill on March 01, 2018, 11:01:47 AM
Thank ya. Wish I could find some shorter turnbuckles.
How about using a through bolt (or an eye bolt) instead of the turnbuckle?  You could still have your adjustment in a more compact package.
Wudman
Charlie Daniels
Ljohnsaw
Quote from: Wudman on March 02, 2018, 11:50:40 AM
Wudman
Just make sure you use a welded eye or the weight might straighten it out!  Don't ask me how I know ::)
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Kwill
The turn buckles I have are working ok.
ktm250rider
i go back and forth on building vs buying guides.  Currently im on the buy from cooks.  Yesterday it was build.
Kwill
Quote from: ktm250rider on March 02, 2018, 03:41:57 PM
Yeah same here. If I buy I'm gonna get them from woodmizer
Kwill
I wonder if a guy could take one of these alternator pulleys and grind the front flange off and use it for a guide
Kwill
 Dropped 130.00 at wood mizer today. Figure if I'm going to do it might as well do it right
starmac
I tend to think you will be money ahead with the factory guides, in the long run.
On a side note, I thought woodmizer had some sort of policy that you had to have one of their mills registered with them to buy parts. I know I have tried to look up some stuff on their website, but can not access all of it for some reason.
Kwill
I haven't had any trouble with there site. I went to our local woodmizer store and bought them
Kwill
Really didn't want to spend the money on them. I sold some stuff I had on Facebook and Craigslist over the weekend and made a little extra cash so it wasn't a big deal.
starmac
I hear you, but like I said, it is likely money well spent in the long run.
I may be doing something wrong trying to access parts on their site, computers are not my strong suit
Kwill
I needed a 1/2 spacer or bushing and didn't have one. So I took a 1/2 nut and drilled it out. Worked perfect.
Ljohnsaw
Why did you need a spacer?  My Cook's came with one...
I drilled out my bolt and inserted a zerk so I can grease the bearings every day.  I drilled halfway through the bolt lengthwise and then halfway in the side so grease will squirt out between the bearings forcing the old grease out both the forward and leeward bearings.
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Kwill
Mine are woodmizer not cooks
Ljohnsaw
You need to make sure the spacer is faced properly so that the front and back face are absolutely parallel.  Otherwise, you will be stressing the bearing by taking the center race out of alignment.
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Kwill
Didn't do anything to the face of the nut.
Kwill
Done a little work on my blade guides today. I think they will work out ok.
jwh f-100
Nice work..
I've been racking by own brain on guides.. still undecided..
Why buy it when you can build it.
Kwill
Thanks. Its trial and error. I Will see how they work out.
Kwill
Building some outriggers for my sawmill track trailer. Got 3 more to build
Crusarius
I am pretty confident that the base of that jack will never wear out or bend.
Kwill
Yeah a little overboard but it's what I had on hand  :)
