Chipper recommendation
Started by SWOregon, November 30, 2020, 05:42:00 PM
SWOregon
I am looking to by a wood chipper, primarily to chip Douglas fir branches and the first outer cut with bark off the logs.  I have a 57 HP Kubota tractor, so probably want to go with a PTO driven chipper.  Any recommendations would be greatly appreciated.  Monte
goose63
I have a Woodland Mill pto 6 inch chipper I'm happy with it
goose
thank you to all the vets
jeepcj779
If I had the money, I would get a Wallenstein BX72r or BX72ri. 7x12 chipping capacity, and the ri version automatically adjusts feed speed based on the PTO RPM. Since I didn't have that large of a budget, a got the Woodmaxx 9900. It has a 9 inch capacity and makes good chips, just not suitable for slabs. I just have to be careful with feed speed depending on the size what I feed it or it will bog down the tractor, which has 37.5 PTO Hp.
snobdds
I have an Echo bearcat chipper with hydraulic feed and reverse.  It's not a PTO unit, but towable.
If there is one thing I can steer you towards that will make you want to use it over and over again is the hydraulic feed.  It adds so much safety and keep a person from overworking themselves trying to stuff branches in.
boonesyard
I too have a hydraulic pto driven Bearcat 9" on a 54hp tractor. Works very well and just eats all day
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
