Powering a M-14 Belsaw mill
Started by Irish_Jake, December 30, 2020, 02:08:15 PM
Irish_Jake
Afternoon all -
I have a recently set up Foley Belsaw that I'm currently running off the PTO of a Ford 8n, which is underpowered for the saw and what I'll be cutting with it (a lot of green red oak, among softer woods).  I'm looking for a standalone engine to power the saw, but not having a lot of luck on CL and FB Marketplace.  Part of the problem is that I don't know what to search for, which ideally is a stand-or-wheeled engine with a flywheel or PTO and at least 50hp, at least as far as I'm thinking.  So what I end up finding is a lot of listings for car engines, or cars, or tractors.
I do have the advantage on my belsaw that my PTO connection is not directly on the blade shaft - it's offset to a second shaft at the end of the saw, and a 7" flat belt connects to the blade shaft from there.  That means that I'm not locked into a rotation direction on my engine since I can run my belt straight or w/ a 180 twist to reverse the direction of turn.  I can also work with either a PTO drive as I have now, or adapt it to another belt drive or other type of connection as needed.  I'd prefer not to deal with the mess of starting from scratch with a car/truck engine though.
Any suggestions on what to look for and where to look for it?  In an ideal world I'd like to find something under $500 that will fit my needs.
sealark37
You should try to find an International Harvester UD-9, or better yet, a UD-14 diesel power unit.  At your $ limit, you may need to do some repair.  Either will more than double the sawing power you have now.  Posting your location in your profile may assist your search.
Irish_Jake
Quote from: sealark37 on December 30, 2020, 02:21:46 PM
Location updated, I'm in West Michigan, Grand Rapids area.  Repair / rough shape is fine.  My 8n is a full rebuild so I'm comfortable with it.  That said if there's something perfect that's a bit higher I'll stretch.
moodnacreek
To bad you are not close by as I am cleaning up around the mill and have the set up That I ran a Bellsaw with. In fact I have 2 0r 3 engines that would work . The way I did it was with a shaft mounted on the power unit frame U jointed to the Bellsaw mandrel. A belt driven governor rigged to the carburator is needed on a car or truck engine. The twisted flat belt eats alot of power, I never liked that but of course I did that first.
Nebraska
Might be able to expand your search farther west and look for irrigation power units or power units from manure handling pumps, 500.00$ for running may be hard to find though.
Hackeldam Wood Products
Quote from: moodnacreek on December 30, 2020, 07:17:36 PM
Probably worth the trip. He could get a good engine with sound advice from a expert.
Happy New Year.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
Irish_Jake
What kind of engines do you have available?
moodnacreek
All ford v8's.  Nothing is turn key.  On one set up is a 302 power unit of a chipper. You would need to extend the frame sideways and mount a drive line and pullies and I would have all this . I should still have the 1 3/4" connection to the sawmill mandrell.
Iwawoodwork
Hey come on West just a little farther,  I have a1986 ford f350 4x4 with a 6.9 diesel that has a lot of miles but runs ok, I was going to use it to rum a Belsaw that I have since sold.
The plan was to cut the frame off at the back of the crew cab, weld a trailer axle there and use the driveline as a pto shaft to the mill.   That was if I ever needed to move it I could use the 4x4 and front wheel drive,
You might be able to find a cheap old retired diesel farm truck in your budget. I just (6mo ago) bought a Allis Chalmers Gleaner combine, full closed cab, with a good AC 3900 diesel, 150hp, complete still able to drive for $500.00 . It has a multiple V belt drive. also hydraulics for the combine head, lots of neat parts.  Look around the farms for old retired swathers or combines, might find a diesel power unit cheap.
moodnacreek
