What blades for my wood and what blade to Plane?
Started by pezrock, July 24, 2021, 01:20:33 AM
pezrock
I have a Woodland Mills HM130 Max with a 14hp engine. I cut 80% Northeast hardwoods and 20% Northeast softwoods.
I recently got 2 different opinions from 2 different reps at Woodmizer.
1. I want to purchase 10 blades from Woodmizer. Which should I get for regular milling?
2. What blade should I get to try and plane cupped boards?
2: consider a carbide blade for that.  They are pricey, but skimming dry wood is hard on a regular blade, and you soon take the set off the teeth. Carbide teeth might last long enough to make them cost effective?
Stephen1
I would buy and use the double hard 10 degree WM blades for your setup. A planer is best choice to flatten boards. You can try a carbide blade to flatten.
   WM used to offer an assortment pack with different blades for such cases. You might ask them and get a pack and try their variety pack to see what works best for you. I am slowly consolidating to on 4* doublehards for all my sawing.
Nebraska
4° Kasco blades are worth a look worked the best with 13 hp Honda on my mill.
firefighter ontheside
10 deg double hards worked best with my mill when I had 15hp.  I use 4deg more now that I went up to 19 hp.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
