Stihl smart connect
Started by Whiplash1, May 26, 2022, 07:45:07 PM
Whiplash1
Playing around with one I picked up today and stuck it on a 400c to try it out, dealer told me it kept track of info on the saw like hours and rpm but so far only seeing hours, which I can see if the dealer plugs it in, I could see the point on a older saw to have a idea how much use it's seen. Or as a business owner with a lot of equipment which is what it's probably designed for. Anyone using these things?
Nebraska
Probably data mining on your phone.....
 I better finish my coffee... ;)
Southside
Not sure what hours and RPM tracking do for the saw owner.  It's not like you are going to change the oil or the bearings at a particular interval.  Sounds like a problem looking for a solution to me.
moodnacreek
I wish they would improve things like gas caps and carberaters, come up with something that would handle todays gas.
jmouton
non ethanol gas is the key,,,never had a problem with carbs since,,,they call it rec fuel too
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
moodnacreek
Quote from: jmouton on May 30, 2022, 08:14:24 PM
So I'm told. What worries me is buying that and getting a mix .  The carbs might as well be plastic as white metal is a problem. Old engines with cast iron carbs don't mind ethanol at all.
