14" wide flange exposed beam . Clear coat , black primer or leave natural
Started by Sedgehammer, June 01, 2022, 04:46:00 PM
Sedgehammer
This is a 48# beam per ft. Flange is 1/2" . 8" wide . We will most likely make some angle shaped brackets that will bolt up to the exposed 3x11 floor joists with 2 , 5/8 sq headed bolts each and the floor joists will butt up together on the 8" wide beam . Then we will use 1" sq headed bolts & bolt the flange to the beam . Wood you clear coat the beam , leave natural or spray paint it with a black primer ?
Necessity is the engine of drive
jmouton
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
Sedgehammer
Tom King
I would want to paint it, but wouldn't want to go to the trouble of removing the mill scale to do it, so most of mine fairs on its own.
Crusarius
Clear coat looks kool. I would definitely do something otherwise overtime it will get nasty and possibly leave rust stains on the floor. Especially if it is in a damp area.
