TimberKing 2000 setworks
Started by DDW_OR, June 04, 2023, 12:29:53 AM
DDW_OR
I am having troubles with my setworks
Anyone near Glacier Park or Kalispell that has a 2000 mill I can plug mine into to see if the problem is mine or something else
Button down does not work, button up works
Have swapped wires at solenoid.
It works
DDW_OR
ordered a setworks from TK, $750
should be here in 2 days. 4 day shipping.
will compare the signals on the two to fix the original. will keep the second one as a backup.
I assume you called TK for troubleshooting.  they can help you determine if it is the encoder or a wire or the setworks.  do not spend money to swap parts.  I had trouble and it was the encoder, and I have also changed the solenoid since.
DDW_OR
my background
91-92 Devry, Electronic Tech course
92-93 Semi tool, running cable and wires
94-2011 Hypercom, component level repair of credit car machines and networking equipment
later did failure analysis at Hypercom
2011 retired at age 42
so on the timberking
encoder = OK. setworks displays correct height
cable = OK
solenoid = OK
setworks = bad.
with engine off, setworks on
press up = relay clicks
press down = no click
inspect circuit board and transistor trace shows burn. no burn smell.
will use O-scope to compare the old to the new. determine what is bad then repair.
Southside
My approach would be different.  I would just give it a good ole "whump", and hope for the best.  :D
DDW_OR
Quote from: Southside on June 07, 2023, 11:04:59 PM
been there and done that, works about 30% of the time
btulloh
It might be worth trying to clean the potentiometer with a spray cleaner. Pots get dirty. The old temporary field fix for a dirty pot is to just exercise it back and forth briefly. A large percentage of potentiometer problems are just dit or glaze build up.
Are these pots carbon or wirewound?
HM126
DDW_OR
Quote from: btulloh on June 08, 2023, 05:25:53 PM
Yes that is a god fix for Pots.
but there are no Pots
btulloh
Looks like I posted in the wrong thread.  I meant to put this in a thread about an LT40 power feed problem.  Oops. :-\
HM126
DDW_OR
got the new setworks
installed
all works
the happy end.
