Plumbing Question
Started by Mooseherder, January 05, 2025, 01:58:29 PM
Mooseherder
This is at my daughter's house.  Anyone know what it is for?  She thinks it has something to do with energy consumption, but it doesn't make any sense to me.  It runs 24/7 and you can hear it on when on the other side of the wall.
   Why isn't it a hot water heater?
Mooseherder
The do hicky on the side of the water heater.
Brian_Rhoad
Could it be a circulator that pumps hot water through the hot side of the pipes so you have instant hot water? You wouldn't need to run cold water out of the pipe to get the hot water.
Google "Grundfos hot water circulator"
Old Greenhorn
OK, this is a shot in the dark but hear me out. (Then you can laugh.)
 This is a valve with a timer that is coming off the bottom of the heater, also call 'the drain'.  Depending on the type of water you have, these water heaters tend to collect sludge in the bottom over time which restricts water flow. It is a very simple thing to just drain the bottom junk off the heater from time to time. My parents house had/has this issue. I would just drain off the bottom 5 gallons and all was good for several weeks or months.
 What you have here seems to be an automated drain that will go 'open' for a short period every few weeks or months and drain that junk off.  I'll bet the other end of that pipe is either in a drain or to the outside. What is the timer set to? how often and for how long does it 'open'?
 It's actually a good idea that should add to the lie of the water heater.
Menagerie-Manor
In the trade it would be known as a recirc pump to maintain the domestic hot water piping up to temp on installations with long runs to the furthest fixture. It's a nice feature having almost instant HW but these days with energy costs being what the are ...
Most systems include an aquastat downstream with a setpoint and range so it's not running 24/7, not familiar with the timer arrangement...
If you come to a fork in the road take it.....
Woodland Mills HM126
Yanmar YM2310D
Stihl 031AV
Stihl MS251
Yep, recirculation hot water loop.
I believe OGH nailed it, seeing that it is an electric hot water heater.
Where does the copper pipe go after it exits through the wall? Known or not? Suspect it goes to a drain, but pump shouldn't be running 24/7.
Ljohnsaw
Probably a recirculating pump. The timer just needs to be set properly if it still works. You'd set it to run just before you get up in the morning to take your shower and maybe again to run before you do dishes so the hot water is there.
A guy I do odd jobs for had a BIG tankless installed to save on his propane usage. Then he had a recirculating pump installed that ran 24/7/365 🤔🙄
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Mooseherder
I don't see where the pipe is going because it's in the wall. Here is a 20 second video of it in action.
I'll do some more research after dinner.
https://youtube.com/shorts/g6-P2A8OJrM?si=WjEHybO4GtZnySHe
Not seeing where any of the timer tabs are set up for any off-time period. If it is pumping off hot water 24/7 then it is far from an energy saverffcheesy ffcheesy
SawyerTed
The timer appears to be set to ON 7 am to 9 pm.  The blue tabs pushed in are OFF and pushed out are ON.
Looks to me like reprogramming the timer to "at home and awake" time set to ON and "away or asleep" set to OFF is needed.
Is there a 7 day timer that could be used?
There is a timer OFF setting on that middle switch.  That should turn the pump off completely
We thought about getting a hot water circulator.  You can put it under the sink, and it lets hot water trickle and pump back though the cold-water side.  pressures are equal so it just circulated.  at some point if no water is used you would have "warmer cold water".  we have an upstairs bathroom, and it can be a minute to get hot water for a shower or to shave etc.  I just brush my teeth first and that gets us real close.  the return water stays in the system and not down the drain.  If they planned it when the house was built, it may be a dedicated return line.  I would have just teed into the cold-water in.  the pump keeps the water going in one direction.  check under bathroom sink and see if there is an extra copper pipe on the hot water side in one of them.
Could feel the copper pipe going out to learn if it is hot water (likely is) and also feel the pipe coming into the cold water feed at the top of the water heater. That pipe going out the wall is going somewhere, and might be good to find out where to learn more about this "do-hicky"   :snowball: ffwave :huh?
Mooseherder
I checked the Grundfos website and they say quiet and efficient.  That it is not. They also mention some are used to cool ac units. That unit (air handler) is in the attic, go figure.  I'll do some more looking into all mentioned including setting the timer.  My daughter said she messed with it one time and they had no hot water when needed so she left it on.
You wouldn't need a circulating pump if it was just a drain.
A circulating loop will come off the drain, and come back to the fresh water inlet iirc. I plumbed one, but never finished hooking it up. The hot water "trunk line" that feeds all hot water fixtures in the house was all insulated to minimize heat loss.
The trunk line was much different than the cold water plumbing I did (all of this was PEX) which used manifolds in the mechanical room with what was called "home runs" I think, which went from the manifold to every water fixture. So there is a seperate leg on the manifold for the kitchen sink, bathroom sink, toilet, etc.
Water heaters drain, not the sink drain.   It could have a dedicated line or just go back thorough the cold side.
scsmith42
That IS a circulating system.  I put one in my MIL's house and also first ran across them on a house in Austin Texas build in the late 1950's.
The Texas house did not require a pump - it used convective action to circulate the water.  Worked great.
Tom's 3638D Baker band mill
Mooseherder
The copper pipe on the circulating unit is hot.  The top right copper pipe on the tank top is warm while the left side pipe is hot/significantly hotter.  My best guess right now is it is circulating back to the heater on the cold side intake?  I'll mess with the timer tomorrow so SIL isn't taking a cold shower in the morning.
Menagerie-Manor
The pump should have no affect on HW delivery other than a delay if it's just for recirculation.
Yanmar YM2310D
Stihl 031AV
Stihl MS251
It should always be hot at the faucet if working correctly.  Our sink takes a minute to heat up, upstairs away from the heater.  we do not have but were told one could be installed.  took a few minutes to understand the concept.
scsmith42
Quote from: Mooseherder on January 05, 2025, 07:15:10 PMThe copper pipe on the circulating unit is hot.  The top right copper pipe on the tank top is warm while the left side pipe is hot/significantly hotter.  My best guess right now is it is circulating back to the heater on the cold side intake?  I'll mess with the timer tomorrow so SIL isn't taking a cold shower in the morning.
The return typically is plumbed into the tank drain at the bottom of the tank. So the way the pump is plumbed it is pushing water into the bottom (coldest portion) of the tank.
Basically these are set up as a return line from the farthest point of the house.
Not related to the question but I was surprised to see that a "water heater drain pan" was not installed and plumbed to a drain or outside.  ??
Mooseherder
Probably because it's in the garage and the floor is lower than the house floor.  It's only 4 years old so it must not of been required by code.
