How to determine how many cords of wood are in log form
Started by Firewood fanatic, May 21, 2025, 06:03:27 PM
Firewood fanatic
Hello everyone, we have a lot of log piles around here and I always wondered how many cords of firewood are in the logs in log form. We've always been able to just try to guess it, but I wonder if any of you guys know of an equation or some sort of system to figure out how many cords are in log form approximately. Any help is appreciated!!
Do you want it from measurements of individual logs ??
Firewood fanatic
No, I want a way to see roughly how many cords of firewood I have in the logs pile I have. I don't want individual log measurements, I want measurements of an actual log pile that has hundreds of logs.
If the logs are the same length, and stacked in a row, then just measure the height of the stack and the length of the row. The face measurement (height x length) will give you the area of the log ends, and times the log length to give you cubic feet, divide by 128 and you should have the number of cords.
Firewood fanatic
Yes, that is how you measure stacked and split firewood, but not actual LOGS, like poles, like 20 foot logs that are going to be processed. How do you measure how many cords of wood are in pole form that are going to be split?
The same way. Get an average height, width and length of pile / 128.
Ljohnsaw
So there is no adjustment factor that split wood will likely pack tighter than logs? Or is it the industry standard that a cord of logs is a little different than a cord of firewood?
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
I have heard a difference of loose thrown vs stacked.  the airspace between the logs is larger between the logs, but no airspace inside the logs.  I do not know the answer, but it is a measurement.  It may or may not convert exactly from one to the next.
TreefarmerNN
One way would be to tally the logs and build a file of the board feet of each species.  Convert that to weight.  Then divide by average weight of a cord, again by species.
This gives some idea of the weight of a cord:
https://measuringly.com/how-much-does-cord-of-wood-weigh/
GAB
Dear Firewood Fanatic:
I read an article many moons ago where the factor that was mentioned for going to log form to firewood was from .75 to .85 depending on various factors.  The article was either on this FF or in the sawmill magazine IIRC.
Some factors such as: how large or small are you splitting, how long are the firewood pieces, how tight are you stacking, (according to my lawyer neighbor it should be loose enough for the chipmunk to pass through and tight enough that the cat can't), etc.
GAB
FF
Measure your stack of logs, then split and stack (or throw) the split firewood. And then you will have your ratio of your logs to your split wood.  ffcool
Firewood fanatic
Thanks everyone for your help! I just I I just watched an "In The Woodward" YouTube video which is him and his brother going up to a pile of roughly 8 foot long logs, that was piled an average of 5.8 feet tall, that was 52 foot long. So the calculation he did was 5.8 multiplied by 52, divided by 16 to get 18.85 cords of firewood, that are in log form approximately. That equation makes sense, except for the fact that he divided by 16, I wonder why he divided by 16, and he didn't even use that fact that they are all 8 foot logs in his equation. Does anyone know why he did this?
Ljohnsaw
Well ...
If you multiply L x W x H (52x8x5.8) = 2,412.8
Take cu-ft and divide by 128
2,412.8/128=18.85 cords.
He took 128 cu-ft / 8 width = 16 used in his calc.
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
It's common practice to estimate the depth of a pile (height) at the mid point of the pile, and estimate the length of the pile and average the log lengths. Get the cu feet and divide by 128 for cords. A more involved task was to have tree length volume tables and measure the log ends, which was species (or groups) dependent to get volume. It's all a guestimate, some will come out close, some might have a wider margin one way or the other. Will depend on how well the piles are stacked.
Like Beenthere said, you can sample the piles and stack it out once split to firewood and get your conversion factor.
That is why you show your steps in school.  he must not have mentioned that step.  If they only deal in 8-foot logs, it saves them a step, but not great for an educational video.  of course, to get a cubic foot or any other cubic volume, you need 3 dimensions.  even a cylinder will have the length x the area of a circle that is pie R squared.  the square involves 2 of the 3, x length.
TreefarmerNN
Quote from: doc henderson on May 21, 2025, 09:05:28 PMI have heard a difference of loose thrown vs stacked.  the airspace between the logs is larger between the logs, but no airspace inside the logs.  I do not know the answer, but it is a measurement.  It may or may not convert exactly from one to the next.
I believe the definition of a cord includes stacking the wood, perhaps even well stacked.  (The wood, not the stacker.)
for sale, I agree, but the definition of a cord by volume is 128 cu/ft.  It might take 144 cubic feet of lose thrown firewood to make a well stacked cord at 128 cu/ft.  It is hard to come up with a better value.  I think a cord of logs is relative and you pay different amounts based on true value by comparison.  Work goes into a cord of firewood, and it should cost more than a cord of logs of the same wood.  true volume, or weight makes things very hard.   Lots of variables.
Cords are always nothing more than an estimation of volume. To know exactly what you have requires weighing and knowing moisture content.
The more measurements you take to get your averages the tighter your estimates will be
Wood is sold here as what it scales in cords in log form,  not what it might make. If I told my suppliers that I was going to start using a 140 cubic foot cord to buy log length firewood from them, I wouldn't get anymore wood.
I use 180 cubic foot for loose thrown wood.
Big_eddy
For a quick rule of thumb, using 16' lengths
10 x1' diameter logs =1 cord
3 x 2'= 1 cord
1 x 3' = 1 cord.
Factor up or down for different log lengths
Firewood fanatic
[/quote]
Thank you!! Yea, the guy in the video just kinda threw that equation out there and acted like everyone understood what it meant, so I was just confused, thank you!
Firewood fanatic
Thank you everyone who has helped me in this I appreciate it!
I guess we need to know, what are you calling a cord? A cord is the equivalent  of 128 cubic feet of wood. Example, 4x4x8 is a cord.
Or are you talking firewood lingo "face cord"?
Firewood fanatic
I call a cord 128 cubic feet, I don't use face cords ever
