Lumbermate throttle problems
Started by Nick S, May 01, 2006, 01:12:46 PM
Nick S
 Greetings from England. This is my first posting on the Forum although I have visited frequently over the past few months. I am having problems with the throttle cable and speed adjustments on my Lumbemate 2000. Any advice on setting up and possibly replacing the cable would be appreciated. The cable seems rather primitive, is there any reason not to change it for a braided type ?
KYPE
 Hi Nick, clad to see another Brit on the forum.Even if you are the wrong side o the border!.Derbyshire almost there though!. As for ur throttle cable,change it for one off a Brigs or Honda mower,there well strong.try local mower,horty dealer.All the best Kenny (KYPE).
stumpy
I used to have a Lumbermate and had the same problem. I went to the hardware store and bought some braided stainless steel cable. I them lubed it and replaced the solid wire with it. It worked great.
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
dail_h
   I broke mine a coupla times at the operators end,replaced the original with one from a local small engine shop,no more problems.
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
JP
Hi NickS:  Many of us have found the B&S 23 to be running below the 3600 rpm required to operate the clutch without slippage---I reccommend getting a RPM tach and cking this out-- if the RPM is down-- 3400 ish a simple fix is to slip a nail behind the loop of the gov. spring -- ck out the Norwood site,  pack posts for details--JP
Norwood lm2000,Newholland 30 hp tractor, log carrier/winch, log arch  JP
Nick S
Tnanks for all for suggestions, I replaced the cable with a universal type motorcycle cable, I also found the throttle lever to be binding on the outer air filter casing( Honda 13HP)this was easily remedied with a knife.
