Mercury 2 man chainsaw
Started by J.Hercules, September 30, 2009, 11:18:15 PM
J.Hercules
I saw this at a parts dealers shop today and wondered if anyone here had experience with one of these saws?  It is a Mercury, Kiekhaefer air cooled. Also, the name Disston is on the cover. I doubt a workmans comp agent would be impressed if he saw it on a job site  :o
Jim
jacob j.
That's a Disston DA-211. They're good saws, heavy, but can be run in one-man mode if you're feeling tough. I've got two of the Disston KB-7 saws which are larger, similar twin cylinder units that can only be run in two-man mode.
Disston DA-211
J.Hercules
Thanks for the info, I knew someone here would have the correct answer.  I guessed at the word mercury because the housing from the point of the y is broken off. Now I see what I thought was an 'r' is actually a 't' which is on the starter cover - murcuty.
Jim
nmurph
is it for sale? i am right up the road!
timberfaller390
Quote from: J.Hercules on September 30, 2009, 11:18:15 PM
Kiekhaefer is none other than Carl Kiekhaefer, founder of Kiekhaefer Manufacturing who was the builder of the world famous Mercury outboard motors. I guess they made a saw powerhead too.
L.M. Reese Co. Land Management Contractors
Stihl MS390
John Deere 50G excavator
John Deere 5103
John Deere 440 ICD dozer
pineywoods
I remember seeing a few of these back in the early 50's. Heavy, took a good man to tote the business end all day. Ran a mix of outboard motor oil and gasoline, about 20:1.
sawguy21
Kiekhaefer did make those engines for Disston but failed to live up to the terms of the contract. After a nasty lawsuit, Disston apparently  tried to make their own and Carl took them to court, the company gave up and the left over engines were put on Wajax fire pumps. I had one, no way I wanted to back pack it. By this time the market for two man saws was pretty much done.
Mike Acres goes into more detail in 'Chainsaws, A History'
Al_Smith
If you've ever seen one run they sound just like a boat motor for good reason .
