Any Chipper mechanics?
Started by woodhick, February 15, 2010, 07:08:46 PM
woodhick
I have a friend that just purchased a Chipper and we are having some trouble with it.  It is an Asplundh style drum chipper.  Cant find a maker, not sure if its Whisper, Altec, Mitts & Merrill or another.  It has a steel plate under the drum that is spring tensioned that I assume controls the feed rate or chip size.  Correct me if I am thinking wrong here.  I had a disc style but have never messed with a drum chipper.  Anyway when we put in a piece that is 3" or so in diameter it will only chip about 3 feet of it and then it  stalls/ slips the belts.  It has a Ford industrial V-8 on it and it runs good.   Does anyone have a manual or procedure for adjusting the bottom plate on this style of chipper?  Thanks.
Woodmizer LT40 Super 42hp Kubota, and more heavy iron woodworking equipment than I have room for.
Reddog
On my Asplundh chuck and duck, the feed pan is adjusted by jack bolts. You set it flush too an 1/8" lower than the bed knife. I have not seen a spring style. :-\
logwalker
I am assuming you tightened the belts?
Let's all be careful out there tomorrow. Lt40hd, 22' Kenworth Flatbed rollback dump, MM45B Mitsubishi trackhoe, Clark5000lb Forklift, Kubota L2850 tractor
woodhick
yeah belts are tight. it's stalling V-8 Ford at full throttle.  Governor appears to working properly.
Reddog
If you can get some pictures, we can look at it a little better.
Om my chuck and duck, I have the bed knife set 3/16" from the drum. The knife clearance .010 to .015 from the bed knife.
The 3/16" can be increased to 1/4". It takes some trail and error to see what settings feed and give the best chip.
