sawing Problem
Started by oregonsawer, December 29, 2010, 04:46:44 PM
Peter Drouin
I just welded 2 fangs on the clamp, pulls the cant down :D .Just be carefull it will rip the cant a part. one of my wm mods works good 8) 8)
terrifictimbersllc
Could drill holes in clamp and insert pointed dogs when needed
Peter Drouin
thats a good one too! I bet that would work 8) 8)
wannasaw
Having this problem with cypress right now and the best answer we have found is to roll the cant 180 at the first sign of daylight visible under any bedrail. I got into so much of it I've just about learned when its going to go up by watching the boards come from around the heart. After seeing slightest daylight the next board without flipping may result in 1/8 to 3/16 of daylight..We've been having a tough time. Good luck. MJ
LT28 70something Int'l Backhoe loader  Kubota L285, Husky 55, F-250 7.3, 12'x6' single axle trailer, Kubota RTV900 w/remote hyd. Iron will...
Stress is tough to relieve as you are sawing.  Yes, wannasaw, flipping 180° at the very first sign of cant lift is the best way to produce uniform lumber from troublesome logs.
