New Stihl Chainsaw
Started by mtnman, January 30, 2011, 06:15:48 AM
mtnman
I was visiting a neighbor down the road and he said that stihl has a new chainsaw that starts itself?
He claims that the rope pull just winds up the selfstarter and then it releases and fires up.
What is the model number of these saws?
Do they work well?
mtnman
sablatnic
Most of the smaller Stihl saws can be bought with that system, brush cutters and hedge trimmers too, and it seems to work fine.
mikerat
I work with lots of volunteers at the Parks dept. and some of our older or smaller stature people have tried them and liked them. Some folks with wrist/sholder injuries still like to come out and cut wood  and use what I call (assist start feature) and it helps.
Mike
WM LT28 logrite 30,48,60 canthook, huskys and stihls, Logrite Buck Arch I have met the best people on this site!
ChrisF
Quote from: sablatnic on January 30, 2011, 06:42:21 AM
I've used a saw that has it a fair bit, an MS250, and among other things that I didn't like about that saw is that Easy2start system.
While I realize this issue won't arise for many of the people who use the saw, me and the guy I work with found that if you were out cutting in the cold and had to for any reason sit the saw down where there was snow, the condensation or whatever caused something in the Easy2start system to freeze so it stopped working temporarily.
So God forbid the saw for some reason stopped (which it sometimes tended to do when idling in those temps) or we'd be walking to the car so it could sit in the heat there to unfreeze.
Jred 2171WH
Husky 242XP
sawguy21
I don't like that the rope needs to be pulled to the limit of it's travel before the system works. It is a bit of a challenge for those with short arms.
ErikC
 My mother in law has a ms250 with that starter. She doesn't run her saw often, but loves the starter. I have used it at her place and it seemed fine to me for that type of saw, not sure on a daily basis how it would be though. :-\
Peterson 8" with 33' tracks, JCB 1550 4x4 loader backhoe, several stihl chainsaws
clww
I'm looking for one that cuts all by itself! :D :D :D :D ;D
Many Stihl Saws-16"-60"
18-Wheeler Driver
ErikC
Quote from: sawguy21 on January 30, 2011, 12:43:04 PM
You don't need to do it all at once. Just let the rope recoil back in and pull some more. It won't try to turn over until there is enough tension to trip the starter.
sharkey
Not that its a bad design, its just that most of us are used to feeling the compression stroke.  Didnt this idea start with Poulan on their simple-pull designs?  You pull the rope to wind the spring tension and then the engine spins once the spring is tight?  Reminds me of the old Briggs crank and spin starter...
John R
Quote from: clww on January 31, 2011, 02:47:42 PM
If you find one, please let me know.
John
Sthil MS 361 20" Bar
Sthil MS 260 PRO 16" Bar
Oregon 511 AX Chain Grinder
stihl_in_texas
Quote from: John R on February 03, 2011, 10:57:24 PM
Better yet, build one and you'll never have to use it.   ;D
Steve
scsmith42
To heck with starting or cutting by itself; I'd settle for one that shapened itself!  :D
Tom's 3638D Baker band mill
clww
So that's Starts, Cuts and Sharpens all by itself....Got It! splitwood_smiley
I'll keep my eyes peeled. :D
18-Wheeler Driver
sablatnic
How about using oregon's autosharp chain on it, that is two out of tree. :-D
SawTroll
Those starter systems do add some weight to the saws, and it looks like Stihls system is the "worst offender" in that respect, at least "on paper".  :P
What I mean to say is stay away if you don't really need it!
Information collector.
