Useful sawmill mods
0 Members and 47 Guests are viewing this topic.
I removed a section of the top (larger) part and then fitted it inside of the bottom.  You can see where I cut slots for the handle, and then riveted it together.  Of course, then the top no longer fitted, hence the black top from a smaller can.   ;D
Bandmill Bandit
Another mod/addition under way.
As you can see no welding done yet as i am still in design stage. Want to make it so that it goes off and on in about 5 seconds or less.
Thinking drilling right through the clamp where I now have the 3/8ths by 3/4 inch bolts holding the little tabs in place so I can use a pin to told it in place that will slide in and out easily.
Any comments or Ideas?
That stuff is a hard drill but good bits and lot of water worked well to get the 2 holes drilled about and inch deep on each side in about 15 minutes.
Bibbyman
Looks like it may be a tad aggressive for clamping a cant.  Might "bite off" a chunk.  Have you tried it yet?
Sawing since '94
I have never seen/had the need for such, but if you do it certainly should work.   ;D
LeeB
Looks like it wood be good for clamping small diameter stuff. I need to do some small cedars and it looks good for that.
Bandmill Bandit
Quote from: Bibbyman on December 04, 2011, 03:28:01 AM
Hey Bibbyman
Thanks for the response. No I havent tried it yet as it is in the design process. I have only bolted the 2 tabs to the clamp and have a piece of 3/16 flat stock stuck in between the 2 pieces that I intend weld in the there.
The question I am contemplating is whether or not to increase the thickness of that piece.
This one will be for use on fresh log with bark still on so I want it to be quite agressive.
I am thinking of making it reversible with 2 or 3 smaller saw type teeth about 1/4 in deep.
Its a work in progress at this point and I want it to be as practical as possible and easy to swap.
May end up with 2 separate pieces as that piece across between the 2 tabs is a fairly important piece to ensure that the clamping pressure remains on the face of the clamp and not on the bolts. The bolts may be a temporary fastening method as I want to be able to make it so I can pull a pin to remove and reinstall quickly.
My ultimate goal is to end up with 3 clamping surfaces and have them very easily and quick to inter change so that it INCREASES out put not decreases it.
I am thinking of drilling the hole all the way through the clamp so that  pin will slide through to hold the clamp pieces in place.
Any additional ideas and comments are welcome.
pineywoods
Looks a lot like my home-made turner/clamp. Yes, you can in fact poke holes in the side of a cant, but that's an operator problem  ;D
Peter Drouin
I put two fangs on my clamp by using the wirefeed then file them down. works good I can even pull the cant down a little if I have to, but be careful not to rip two lines down the side of the cant. just have pull away first :D :D :D
customsawyer
I have the same question as some of the others. I am not sure I understand the need for this mod. Can you please explain what you plan to gain from this.
www.thecustomsawyer.com
Peter Drouin
Customsawyer , sometimes if the bark is loose and the log will want to turn on me the fangs will hold it. or pull off the bark and clamp it , I would show you a pic but my file is to big :D :D im in error :D I can;t seem to post a pic, it;s in my gallery, ill keep trying :D :D
Pete
Just copy the info in the box below your pic in the gallery and paste in your post like this
customsawyer
Peter I am not trying to question you just trying to understand.
What size logs are you milling that you need this mod on and what kind of log is it.
I cut some pine logs that have thicker bark that when it has dried a bit the bark will slip very bad but I haven't had on try to turn on me unless it was 8" dia. or less. I try not to mill this small of a log for several but this is one of them. If I do have to mill logs this small I usually cut 2 or more logs at a time so your mod would not help to hold the inside log.
POSTON WIDEHEAD
Saturday night I sat down on my couch and read every post in this thread. It took me a little over 3 hours and  45 minutes.
I am very impressed with the ideas you fellows and gals came up with! The pictures were great when needed. If anyone hasn't read 'em all.....DO IT!
I wish they were all in a book...but now we have a computer.
Thanks for the ideas. smiley_applause
Peter Drouin
  thanks for info customsawer. not somuch small logs old w pine the
  canbium layer is slippery like ice and the clamp fills up with the slime and slips. all so when im cutting hemlock and hit a knot the cant will lift sometimes if the back stops are to low. I have hit them with the blade :D :D so I keep them on the low side :D. sometimes cutting r oak and I get down to the last cuple of cuts I reposition the clamp the thing will pop up  :o the fangs will pull it back down ;D
Is there such thing as a "picture echo"  ???    :D
Bandmill Bandit
Yes Peter
Exactly the reason for my mod in process. Small poplar and western birch and a few others that like to pop/slip up before/while you are opening the log. That the reason I want to be able to remove quickly. As a rule only need it on the first 2 some times 3 cuts depending on the log and how you open the it.
I have had Poplar and Birch pop up during a cut and that is very annoying.
Peter Drouin
 :D :D :D ya MM sometimes I don;t do so good with the computer  :D :D I saw logs better :D :D
   :D :D
Peter Drouin
In 08 when I gut this mill, It gut a seat with it  :D. but the seat is black and boy is hot on your but in the sun :o :o. so with some junk I had around I made this.
  and it slids in to a pice of 2" chanel welded to the bottom of the seat ,
  I use it when im on a job and the sun is out , and keeps my but cool :D :D :D
Yup, the only thing better than a seat is a seat with an umbrella on it.   smiley_thumbsup
paul case
I am guessing ya don't use the umberella under the building?  PC
pc
Peter Drouin
 :D :D :D :D No It;s that I had the camera with me the outher day , so I thought you all  would like to see how I did it  :D :D maybe it will help :)
Brucer
I tried something like that once. Big windstorm blew up and next thing I new the umbrella was floating on the breeze -- out over the highway that ran through a cut below my milling site.
I didn't hear any squealing brakes, but I didn't find the umbrella either ???.
Some things weren't meant to be :(
Bruce    LT40HDG28 bandsaw
PC-Urban-Sawyer
Quote from: Brucer on December 14, 2011, 12:28:11 AM
Seems like a pin through the mounting bracket and umbrella shaft would have prevented that problem...
Herb
Brucer
That was plan B.
Just so's you know, when the wind pops the umbrella upside down, it's just never the same again :(.
