Lt40hd24 blade guide problems?????
Started by Bolie, March 24, 2012, 12:43:27 AM
Bolie
Sealed guide roller bearing had little slack in it ,found a old roller with alemite that came with mill and changed it but then new blade starts chattering and leaving little ripples in sawed boards so put sealed bearing back on to try to finish day..stilll making ripples but not as bad.Fixing to order 2 new rollers.Does anybody know what I,m trying to say?any feedback will be greatly appreciated!!
                                      Thanks Bo
If you want to do something bad enough you'll find a way,If you don't you'll find an excuse!!!!!!!!
Brucer
Did you adjust the blade alignment when you put the new rollers on? If the rollers got out of adjustment when you were changing them that would give you a ripple.
Bruce    LT40HDG28 bandsaw
Chuck White
The rollers need to be adjusted so they are level with the bed.
If they are tilted up or down, they will not saw right.
Follow the alignment procedure as outlined in the owners manual.
Magic Smoke
There might be a small flat spot on that old roller.
Sawmill Man
    Being that the ripple was little and there wasnt much change between the different rollers I would look at that new blade real close for incorrect hook and set.
"I could have sworn I went over that one with the metal detector".
pineywoods
May not be the rollers. A slipping drive belt will do that. IF it is the guide rollers, could be not enough down pressure on the blade.
Bogue Chitto
I had that problem one time and it was the drive belt.
Sawmill Man
   Too much hook and or set is guaranteed to bring on the drive belt problems if belt tension is just barely enough before the blade change. Changing from a low hook blade to a higher hook tooth is going to stress the drive belt more and possibly cause slippage where there wasn't  any before.
Brucer
First rule of troubleshooting -- whatever you just changed is most likely where the problem is. When you replace the blade guide rollers you usually end up messing with the adjustment.
Bolie
you probably right Brucer gonna have to bring wm mechanic to fix it when i get thru adjusting!!
Chuck White
Another thing to remember is "only change one thing at a time", or you're asking for trouble!
