My New Stove-wood Processing Tool
Started by CTYank, July 20, 2012, 06:06:54 AM
CTYank
A 14" Grizzly bandsaw with 3 tpi band. (G0555LX, should you ask.)
My little Morso works best with 8" long splits. They don't stack well, slowing air-drying, so the sticks in the stacks are 16". Usable in friends' fireplaces besides.
Been using a "disposable" HF 10" tablesaw, but that's been getting old. Forget chainsaw.
Bandsaw has much narrower kerf- about .040" vs about .1" with tablesaw- less waste. Fewer ways to get hurt with bandsaw than tablesaw- they don't kick backward/forward like tablesaw or chainsaw. Fast-cutting 3 tpi blades go for little over $10. Used indoors, much easier to control dust via Shop-Vac connection.
Discovering, meanwhile, the many other neat things a quality bandsaw can do. Wish I'd done it sooner. Resawing cherry firewood forks can show off some spectacular grain. Some stickered stacks are now drying slowly.
Nobody's got any comment?
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
Husqy 576XP-AT
Mix of mauls
Morso 7110
westyswoods
What are you doing cross cutting or using it as a splitter, guess I am missing something here.
Stay Safe and Be Healthy
Westy
r.man
Whatever works for you is good. Knew a fellow who processed all of his winters stove slab wood with a skillsaw. Moved the slabs with a small truck and then would slide the pieces onto a workbench to be processed. It worked well for him for years.
Life is too short or my list is too long, not sure which. Dec 2014
CTYank
Quote from: westyswoods on July 30, 2012, 08:26:51 PM
As stated, taking 16" long splits to 8" long. Cross-cutting is the only way. (A 14" bandsaw can buzz sticks that will stand on their sides less than 6" vertically to ~14" long. Without riser. Can't conceive of reason to rip 16" splits, except maybe part-way, through nasty knots.
Main point is that a 1 hp motor can drive a 3 tpi band in such a machine so that it quickly slices up stove splits in a safe, efficient manner. And when you can buy that bandsaw for $445, why not?
Echo 315, SRM-200DA
Husqy 576XP-AT
Mix of mauls
Morso 7110
