Chainsaw Mill Opening day...delayed...rain &
Started by oldsaw, March 28, 2004, 01:55:28 PM
0 Members and 10 Guests are viewing this topic.
oldsaw
delayed shipments.
Well, rained out this weekend...same story for 5 months.
But, I got some necessaries done.
Alaskan is assembled and adjusted to bar.
066 has been cleaned up (came with 1/2 a tree, in kit form, inside the case...free!!!).  Clutch hub was a mess inside, but bearing was good.  Pulled the clutch and found a cup o'crap behind it to clean out.  Scuffed up the contact bits and inside of the hub, replaced .404 sprocket with 8 tooth 3/8", and wired the 7 tooth and .404 together, tossed them in the "toolbag".  Air filter was a real mess, but now clean.  Spark plug was good.  Fueled it up, took a dozen or so pulls to get fuel up to the carb, and....BRRRROOOOMMMBBBEEDDDAAAA...BOP...
BURGLEBURGLEBURGLE...BOP....BURGLE in a deep husky (small "h", not like the saw brand).
Set the idle down a bit, leaned out the idle mix a bit, beefed up the high speed mix a touch, and, DanG, I've got myself a saw.  It aint pretty, but she runs (I resemble that remark).  Put her down for an hour or so and went back.  1st pull, we were back on.  Not too worried about compression on this one.  This is one running machine.  Can't wait to put her into a log.  Just need the Aux Oiler and my three rip chains from two different places, and my 20" bar.  I'll have 2 of the rip chains on Wed, but leave for Montreal on Thursday through the weekend.
You know, there isn't anything that sounds quite like a big two stroke at idle.
So many trees, so little money, even less time.
Stihl 066, Husky 262, Husky 350 (warmed over), Homelite Super XL, Homelite 150A
Stan
QuoteYou know, there isn't anything that sounds quite like a big two stroke at idle.
Well them V12 Packard Rolls Royces in the Mustang fighter sound pretty mean at full chat.  ;)
I may have been born on a turnip truck, but I didn't just fall off.
Kevin
oldsaw
a 2x8 for the little ones.
Fortunately, most of the logs are very straight and have very little taper.
Kevin
Just to mention ...If there's any curve in the log the plank will follow it and the mill will follow that.
Every board will be curved, that's the first thing I discovered with the chain saw mill.
sawwood
 Mark to bad it rained, sure was looking to see it in action.
 I sharpen my chain on the little sears saw and cut a bowl
 blank. Now to turn it in to some thing. When you git back
 give me a shout and will git to turning.
 Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
QuoteBRRRROOOOMMMBBBEEDDDAAAA...BOP...
You my friend NEED to get yourself a 090.. just so you can start it up and listen to it :D 8) :D
