Replacement spikes
Started by CCC4, December 17, 2012, 07:22:44 PM
CCC4
I am only getting a couple months out of my spikes on my boots. I was wondering if you guys had a preference for what brand you replace with. I am in really rocky ground, boss's son got him some hardened steel spikes, I figure they will break on the rocks??? Anyway any suggestions will help. Oh, they are Hoffman boots if that makes a difference. Thanks!
Sorry for improper jargin (spikes) possibly corks?  ::)
redprospector
If you're on real rocky ground, you're going to wear them down pretty quick. I've never tried hardened calks, I get mine from Bailey's when I need them.
Andy
1996 Timber King B-20 with 14' extension, Morgan Mini Scragg Mill, Fastline Band Scragg Mill (project), 1973 JD 440-b skidder, 2008 Bobcat T-320 with buckets, grapple, auger, Tushogg mulching head, etc., 2006 Fecon FTX-90L with Bull Hog 74SS head, 1994 Vermeer 1250 BC Chipper. A bunch of chainsaws.
kderby
You might need to consider them disposable like chainsaw chain or teeth on a backhoe bucket?  Thanks for the question. I might lern ;D something!
You should get a year out of them. I work on rocky ground thinning and get two seasons from them.
Mine come from Deakin Equipment in Vancouver, but I suspect they are all the same unless they are Chinese knock-offs.  ::)
Make sure you have the little caulk wrench to replace them if you order some. These type screw on. The boot soles have threaded inserts. :)
If they are the inserted studs like on tires, then they don't last worth beans.
Wrench
ceramic caulks
hardened steel
Try Bailey's first.
I use the hardened steel and usually the boots bust out before the caulks are worn out. Thinning is very hard on boots. ::)
CCC4
Thank you for the replies.
SwampDonkey, these hardened spikes are made by Phillips. I haven't tried them yet, I was a little concerned that the "base-plate" is smaller in diameter, plus I have lost my wrench and the Phillips wrench has different pin spacing. Guess I will try the hardened for a bit. Thanks again!
nhlogga
I get mine from Hoffmans. They seem to last longer than any other spikes I have tried.
Jonsered 2260
Husky 562xp
Bigredfaller
Tungsten are the best for rocky ground.... they actually get sharper as they wear. I am a full time faller and change my caulks every couple of shifts (2-3 months) Nothing worse than dull caulks, sharper is safer!
Husky 390's 36"-42", 05 duramax, Norwood Lumber mate 2000, Timberjack 225
CCC4
Thanks for the info on the tungsten, I will definitely check into them! Thanks!!
