My LT-10 is now mobile!
Started by francismilker, March 12, 2013, 10:31:55 PM
francismilker
I finally got around yesterday to starting my boat trailer retrofit to make my mill mobile.  I spent several hours welding, fabricating, and painting.  By end of day tomorrow, I ought to be able to make a board or two at someone else' house.  I still have to cut my leveling legs out of some long stock, mount the tongue jack, and put some trailer lights on it.
So far, I've made a cantilever arm for loading and rolling logs with a winch, installed 6 leveling leg recievers with T-handle bolts, and used two scissor jacks to put some toe board levelers on each end of the mill for leveling my logs on the first two cuts.  There's more to come. Rome wasn't built in a day.
I took lots more pics but am having quite a lot of difficulties getting them uploaded.  Every time I'm almost there I get a message that says "internet explorer has stopped working to protect your computer from this website"  Anyone want to give me any suggestions here?  It's probably user error. :o
"whatsoever thy hands finds to do; do it with thy might" Ecc. 9:10
WM LT-10supergo, MF-271 w/FEL, Honda 500 Foreman, Husq 550, Stihl 026, and lots of baling wire!
hackberry jake
Looks like you did a fine job! Almost looks factory!
scully
Wow ! awsome work ! these mills are real popular but seldom do you see someone go to the extreems that you have ! You just added a couple grand to the tag on that one !
I bleed orange  .
MEMountainMan
It looks really good. I'm kickin around the same thing for my LT15. Now that I have the sawmill everybody has logs to saw.
LT15 30 feet cap. (STOLEN), John Deere 850 tractor with a loader bucket and backhoe (STOLEN), Woodland Mills 130 Max with extra track (2025), John Deere 1010 dozer. some husky saws. A shop full of tools and 108 acres of trees to make things out of.  Done building homes for others now it's my turn
That does look good. I have no idea about your error code. this user gets enough errors codes too.   ::)  I usually only load no more than 3-4 pictures at one time,just because that's all I have at one time.
francismilker
Quote from: scully on March 12, 2013, 11:02:10 PM
Believe it or not, I only got a little less than $200 in it after I picked up some cheap, used tires today.  I couldn't find any 165/80/13 new locally without ordering them so out of inpatience I bought some good used ones.
The gallon of Implement Orange paint was the most expensive item at $44 per gallon!
Thanks for the compliment.
Tree Feller
The trailer looks great. Does it also have leveling jacks?
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
francismilker
I didn't put leveling jacks on it.  Instead, I welded on 6 vertical pieces of square tubing with T-bolts on them that I can drop leveling legs in.  I'll use one bottle jack or something similiar to march around and level it with one leg at a time for now.  I have plans of installing a water level tube with several upright sight glass guage glasses inline to make quick work of leveling but the hardware store was closed today for me to get clear tubing and barbed fittings. I might get to it tomorrow.
I've got a metal box that's roughly 2x3' that I'm going to mount to the tongue to keep extra bands, hard hat, gloves, and countless other things that are a must with me at all times.
I've had dozens of calls up to this point to come to someone's place to slice up a few cedars but haven't been conveniently mobile enough to do it.  Oh well, if I never get a mobile call I'll not be stooping over to pick up slabs anymore!
giant splinter
That was fast and a great job, glad you bought new tires and wheels ..... I could see the air in the far tire in your photo
roll with it
VictorH
Advice on Internet Explorer is to stop using it  :D and switch to Chrome or Firefox.  Nice trailer and mods btw.
Chuck White
Real good job on the trailer build!  smiley_thumbsup
OlJarhead
Wow!  Fast!  Here I am MONTHS in the making and still only barely able to move mine!
I'm curious how stiff the frame is?  Do you have ramps to load logs?  A pulley system?
Looks great!  Did you rattle can the frame?  That's what I'm thinking I'll do since heavy use will pretty much destroy any expensive paint anyway!
francismilker
I do have some ramps made out of pipe and stiffened up with angle iron for log loading.  I built a cantelever (hard to see in the pics) that slides in to two recievers under the trailer near the axle with a winch mounted atop it for loading.  I also put a boat crank winch back-up in case of low battery.
I didn't rattle can it.  I went to Sherwin Williams and bought a gallon of laquer based "Implement Orange" paint (Pretty close to WM orange) and sprayed it with a HVLP paint gun.  It didn't take much thinning as I wanted to put on a pretty heavy coat of paint.  It won't look good for long though I'm sure.
I took the trailer on a road trip today and drove my normal county road and highway route.  It tracked really good behind me and didn't seem to have much flex or tweak as I tight cornered or manuevered tilted turns.  When parked on level ground hooked to my pickup, it seems to have a little sag on the tailend which doesn't bother me much.  The leveling legs will take care of that.
I put my new lift assembly cylinder on today and didn't fix the problems I'm having with raising/lowering the head.  I've got a call into WM service dept. to get some more advice.  They are looking in to it and will call me back a little later.  Once I get it to where I can lift and lower the head, I'm off to sawing!
m wood
francismilker, I see your in OK.  What did you do for registering, license, tags etc.?
mark
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
rimshot
HIi fm,
Excellent job on that trailer.
I still can't figure what has changed on the lt10 that makes yours and mine along with HandyCamper's brand new LT 10's so hard to operate the head up and down.  They have made LT 10's before and never had this problem.  All of a sudden,the heads don't want to move up or down anymore.  Seems like something has changed, but what is it.
These are very nice units but I have to give them an F on that darn head assembly and I hate to do that because they are a great company.  Anything on a log mill designed to move has to move especially the motor head.  That's all there is to it. What's changed that makes the new units so darn hard to use.
The last I knew they were going to experiment with a new higher poundage aircylinder but I have heard nothing about results.  It was supposed to be tested Tuesday.  I am banking on WM to make this right along with others.
rimshot
LT 10 with a 10 h.p. and a converted boat trailer to provide mobility for a once permanent mill.
Happycamper
Great job on the trailer (very professional) you'll get a lot of use out of it being mobile.
                                    Jim
Wether you think you can or you can't you're right
Skoalbandit78
At first I thought that you had made a mistake and made the trailer upside down  :D.
Good job!
POSTON WIDEHEAD
Quote from: WDH on March 13, 2013, 09:07:55 PM
Good job!
oz_smiley˙ʎɐʍ ʇɐɥʇ ʞuıɥʇ noʎ ʎluo
francismilker
Quote from: m wood on March 13, 2013, 04:28:53 PM
mark
None needed in OK since it's under 26000 GVW.   There's redneck trailers all over the place without any registration.  I did put rear lights on it, but that's all I need to be legal.
