Help Please Marty or Sparks or anyone familiar with Woodmizer Auto clutch
Started by Percy, February 13, 2018, 09:33:08 PM
customsawyer
One thing I have recently found on my mill is some of the spade connectors on the sensors have started to fail. They will look fine and will work when the sun, moon, and stars line up. Found the connector that was bad and then found another that was getting ready to go. Keep a eye on them folks.
www.thecustomsawyer.com
When you say the spade connector failed, are you saying that the wire came loose from it or the tension was lost between the male/female connection?
customsawyer
Ga Mtn Man
customsawyer
I had 2 where the connector broke and one where the wire broke at the crimped end.
