Beginner sawmill?
Started by gman98, August 15, 2018, 08:04:55 PM
gman98
Hello guys.  I've been tossing around the idea of getting myself a small sawmill to play around with and possibly try to make some money on the side with.  I'm mostly looking to saw softwood.  I'd like a mill with the ability to saw shingles as well.  I was wondering what you guys would recommend for a good beginner mill that won't break the bank?
Forest technician and part time equipment operator.  Looking to get set up with some logging equipment of my own.
dgdrls
Hi gman98,
I guess you could saw a wide cant  and make shingles on most any band mill.
I believe a few of the sponsors to the left on the page make a purpose built shiplap and shingle tool.
I suggest you test drive a bunch of mills before you decide.
FWIW you'll want as big a mill as you can fit into the budget ;)
D
sawmilljoe
Any of the Woodland Mills  will serve you well
YellowHammer
 I vote for LT15.  It's a workhorse.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Southside
Good advice for sure, but another way to look at it is like removing a bandage, it's always more painful to do the slow pick and pull, just get it over with and order an LT Super 70 Wide.  :D
White Oak Meadows
Thomas Bandsaw in Brooks Maine. They have changed some. Some for the better,some not. I like the moveable bunks on mine. I can can cut a stove wood piece of wood.When Jon brought the mill to me back in 2007,we levered it. Have not levered it again. Been some good size logs that got turned and banged down on that bed too.But all this does add to the cost too. Only trouble I had was a guide bearing.
I saw them just tilt the head to make clap boards at a show. Use to have to saw cants,than buy a clapboard jig and put the cants back on. Tilting the head allows less handling. Saw the cant than tilt the head to make clapboards.
SawyerTed
Quote from: Southside logger on August 15, 2018, 10:46:44 PM
LOL!  My beginner mill was a chainsaw mill.  My beginner band sawmill is an LT35.
rjwoelk
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Timbery is owned by Wood-Mizer is is another entry level sawmill choice:  Timbery Portable Sawmills
pwrwagontom
I've found the newer production Wood-mizer LT10 to need a few minor modifications as I've learned, however it was built extremely well, customer service was excellent, and I have sawed a hell of a lot of lumber on it in the last two years.
This being said, if I had to do it all over again?  I would order an LT15...if $$$$ is the main issue, buy the new LT15 START.  You can add all the other LT15 extensions, and accessories to it as you get more experienced, and want to do more.  Trust me this is going to happen!!!
Never give an inch
