Made From Wood
Started by Ron Scott, April 01, 2018, 07:54:32 PM
Ron Scott
RE:  BICYCLE FRAMES MADE FROM ENGINEERED HARDWOOD
Another interesting way to use wood in place of non-renewable materials.
The bikes demonstrate some physical properties we might not normally think about.
Not a bad deal . . . if you have a few extra thousand dollars burning a hole in your pocket.
 https://renovobikes.com/
~Ron
GAB
Interesting article, but since I am not suffering from having a few extra thousand dollars burning
a hole in my pocket I will not be joining the in crowd any time soon.
GAB
DelawhereJoe
I've "seen" bicycle frames made from bamboo, I say seen in quotes because it was on "How its made".
Klunker
Quote from: Ron Scott on April 01, 2018, 07:54:32 PM
How is steel and or Aluminum a Non-Renewable Material?
If I remember correctly Steel is the most recycled mat'l out there.
Renewable or recycled? If your recycling a material an unlimited amount is the end result the same?
