Mill alignment
Started by Crossroads, December 09, 2018, 01:23:18 AM
Crossroads
Since it was a tropical day today with a high of 34°, I called a friend from church and asked if I could pull my mill into his shop and do an alignment. It seemed like it was binding as it got to the home position, so I started crawling around looking for anything that could be binding. I found that the front bottom roller was seized up. With some wd40 and atf, I was able to get it spinning free, but she's a little rough. Adjusted the feed motor belt and the drive belt. Set the cantilever, guide arm and leveled the guide rollers.
I was surprised to find the inside guide roller was close to a 1/4" out of level, typically it's the outside roller that I have to square up.
Sawmills be they band or circular are not a "set'm and forget'm" machine. Be alert to any changes and follow them upstream and locate the cause. Frank C.
opticsguy
I have always assumed a band saw mill would require plenty of maintenance and adjustments over time.
I am very surprised that my now 9 year old TimberKing 1220 has never required any adjustments other than guide bearing replacements and small adjustments to the log dogs.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Southside
You might want to get a spare cam follower (the roller you describe) and have it on hand.  The penetrating oil trick will work for a little while, but she is on her way out, I would think it is still under warranty?  That is early for one to go.
White Oak Meadows
Crossroads
Quote from: Southside logger on December 09, 2018, 10:59:45 AM
Yep, your absolutely correct. If I didn't have to move the mill, I wouldn't have even put it back in. I still have a year of warranty left, I'm sure WM will take care of me.
Crossroads
Called WM today about the seized up cam follower. The only question was what address I want the new one shipped to for Warrenty. Sure is nice to work with a company that stands behind their products....
I keep/carry a couple of spare cam followers.  Only once have I had one to seize, but I was sawing very far from home (327 miles) when it happened.  I was back to sawing within a half hour.  I also carry a spare blade guide (old) and also a blade guide replacement bearing kit which I have had to use once.
esteadle
Quote from: opticsguy on December 09, 2018, 10:50:47 AM
Be careful, you may be visited by the ghost of Christmas repairs. he hee.
Crossroads
Quote from: Magicman on December 10, 2018, 08:39:37 PM
I've been dragging my feet on putting together a just in case kit. I'm gonna have to get on that sooner than later.
terrifictimbersllc
Quote from: Magicman on December 10, 2018, 08:39:37 PMI also carry a spare blade guide (old) and also a blade guide replacement bearing kit which I have had to use once.
MM are you speaking of the guide roller and roller bearings or the guide arm?
Not the guide arm.  Old (worn) roller blade guide e/w bearings and also a bearing kit for the roller blade guide.  Actually the bearing kit is poor economics because it is ~$25 whereas the entire blade guide with bearings is ~$55.
I have replace the bearings on the truck tailgate before: Tail gate repairs in Sawmills and Milling
