Minor Problem with 2005 LT15
Started by firefighter ontheside, February 08, 2018, 08:20:30 PM
Woodpecker52
I have them on my Grizzly bandsaw in my shop.  I got so tired of stopping after each log to clean the belts especially after using water lube, it was part of the routine, since I put them on the mill  I have not had to clean the belts once!! even when cutting pine.  The thing is the brush is just a shoe brush and the bristles are very soft, I think that it does not deform the belts ability to flex like it should at the free end of rotation but  just enough lite contact to keep the dust from being compacted on the next rotation, one of the best things I did so far.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Escavader
Felts absolutely sucked on mp100.shavings on track a night mare.added an exhaust 60 percent better.strapped a board to deflect it another 30 percent better .still getting it on further track.ive making a hookup for a low volumn air line to blow off as i go.
  Havent had issues with lt 15 yet
Alan Bickford
Hammond lumber company/Yates American A20 planer with dbl profilers Newman feed table multiple saw trimmer destacker automatic stacking machine Baker resaw MS log corner machine  4 large capacity Nyles dehumidification kilns JCB 8000 lb forklifts woodmizer lt 15 and mp100 and blower
booman
Woodpecker, what is the blue gear and chain shown in your pictures?   Is that an LT15?
2019 LT15G25WIDE, 2013 LT35HDG25, Stihl MS880 with 59" bar with Alaskan sawmill attachment.  John Deere 5045 tractor with forks, bucket and grapple.  Many chainsaws.
booman
What I have used for my LT15 is a strip cut from an old heat shield and sound deadener mat I had and spray some Permatex headliner and carpet adhesive on both areas and then stick them together.  Never had one come loose.  Of course you need to put some atf on it.
Woodpecker52
I added a chain drive system to the lT15 and since it is stationary went with a gear motor and ac 1hp motor.  So I had problems with thermal switches with starting and reversing the ac motor ( the duty cycles not made for this they like continuous operation)  So It dawned on me I only need to catch a ride on the chain anyway and  since it is faster to pull back head, hence the blue sprocket which I simply drop into the chain channel and catch a ride on the chain, when I am through with the cut I pull up the sprocket and pull the head back then start the cut by hand then drop the spocket.  I have cut switches at ends of mill and on the head.  The chain I can leave running in one direction  all the time, no start, stop reverse and the problems blown fuses etc. just simple on off.  It is simple, is as easy as changing gears on a bike, If the log cut is to hard and starts to bog engine, I just disengage and finish by hand, and adjust speed elsewhere ( I can adjust pulleys or change speed by controller)  If I just want to cut by hand I can just raise sprocket, the chain runs in a square channel that fit perfect under the head beam and lock pins. You can see the system on my gallery page and past posts.
Brad_bb
Escavater, how about some pics of what you are talking about.  I have an MP100 also.  Been using it since 2014.  I have a blower sucking chips and spitting them in a giant box in the next room (which is the dusty half of the pole barn).  Interested in what you mean my exhaust and how you use a board?
Woodpecker52
Last picture then I will shut up!
beav
Woodpecker:
Early woodmizers had a sprocket at each end like you have untill they got sued when someone's fingers didn't quite make it around the sprocket. Some sprocket covers might be a good idea?
Woodpecker52
I added sheet metal shields at each end and the middle sprockets have a shield also.  They would certainly take a finger smooth off!  The gear motor itself was used to lift heavy warehouse doors, there is no stopping it except by killing power hence kill switch at each end and on rig head by handle I have a Dayton long handle switch.  I never send the head down by itself but walk and monitor cut with hand on handle.
Did you ever see a topic and open it because it might interest you only to find out it was a topic you started last year.  Well, that just happened to me.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Brad_bb
My fault.  I need some felt for a project and I remembered in one post someone said something about using felt from a tractor supply or farm and fleet and was searching for what it was from.  Couldn't find the exact post I was looking for when I came across this one talking about using felt to repair the rail wipers on the mill.  Then I found a better source via Grainger and McMaster Carr so I added that info to the post for anyone that is looking for felt in the future.  But then some other made some new content and posts....  That's happened to me too, but sometimes it's a post I never saw, or forgot the good info in there, so it was worth the re-read.  ;D
Woodpecker52
wonder if magicmans  has the same thought with What you sawin!
