Guess the carnage
Started by moosehunter, April 21, 2019, 02:38:38 PM
moosehunter
Started this job last Sunday when I got home from a small saw job. Working evenings when I had time and this morning I am finally ready to put it back together. Here is a pick of the pieces involved with getting this far.
A hint; I had to listen to the obnoxious noise all the way to the job and all the home.
In my past life I did this procedure countless times and even had other garages send me these jobs because I was so good at it. I never had one fight me as much as this one.
So what are the pieces from?
mh
Higher than my expectations
lxskllr
moosehunter
Correct! 4 broken studs. I had to drill one, the other three came out by welding on to the end of them.
mh
lxskllr
I just had mine done on my dakota. It's beyond my skill level and desire. That's probably one of the worst jobs you can do on a vehicle, no?
Bruno of NH
Had that done last year on my GMC 1500
Resonator
It looks like you were "warming up" rusted bolts with the acetylene torch, and then hit the oxy lever.  ;D
Independent Gig Musician and Sawmill Man
Live music act of Sawing Project '23 & '24, and Pig Roast '19, '21, & '24
Featured in the soundtrack of the "Out of the Woods" YouTube video:
"Epic 30ft Long Monster Cypress and Oak Log! Freehand Sawing"
moosehunter
Quote from: Resonator on April 21, 2019, 05:51:30 PM
No. I use a mig welder to "build up" a stud that is broken flush or recessed in the head. Then weld a bolt on to the build up. Usually break the weld off a few times before enough heat transfers to loosen the stud. Usually it takes 3 to 5 tries per stud. This time I did it over 30 times for the 4 studs, so approximately 8 welds per stud.
mh
GAB
If I am reading this correctly you are saying that you had a 650% failure rate.
Congratulations on getting 'er done.
Gerald
moosehunter
That's the way I roll  :D :D
Weekend_Sawyer
Wow.
My mother would have said you have the patience of Job.
Imagine, Me a Tree Farmer.
alan gage
Nice work. Knew what they were as soon as I saw them.
We do quite a few of those here at the shop. So far we've gotten them all out but always tell the customer we can't guarantee it. Worst one we had was a V10 Ford where 18 of the 20 studs broke off.
My dad is the go-to guy for that here. He never tries drilling anymore, just straight to the wire welder. For many years he's been welding big nuts to the broken off studs but a couple years ago someone suggested welding a washer on first and that's worked very well for him. It's easier to get a good weld with the washer as it gives better visibility and access for the tip of the welder. Then weld a nut to the washer.
Like you he has a lot of them twist off multiple times before they finally come out. He's always a little giddy when the last one is done.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Crusarius
I stopped trying to do that using nuts since it seems I could never get good penetration I usually use a piece of 1/4" flat plate with a hole drilled in it. I like the washer idea.
terrifictimbersllc
I thought it was a homemade stump grinder.🙂
