bolt size
Started by sawwood, March 28, 2019, 08:29:16 PM
sawwood
 I needed a new blade roller on our mark 4 Norwood and i had  a spare one. When i went
 to install it i notice the bolt that holds it is smaller then the inside of the bearing. I looked
 in the parts listing and the bolt is a 5/8 size. I took the bearing to tractor supply and a 5/8
 bolt is also loose in the bearing. I looked at a 16mm and it was loose and a 18mm was to
 big. On your guys roller is the bolt that holds it small to or does it fit the size of the beaning?
 Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
