Belt size and how many pulleys
Started by welderskelter, April 10, 2019, 11:02:04 AM
welderskelter
I built my mill and I am putting a larger engine on it. Not sure if I need an extra pulley for the extra power or not. I am going to a 20 hp. engine. Just used a single on the 17 hp. Harold
millwright
My WM with a 25 hp has a double belt, and at times it will slip if tension is not really spot on. I would go with 2.
donbj
As millwright says, go with a double. My 24hp Woodmizer can do the same under heavier load if tension isn't up there
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
