V-Belt type band wheels
Started by adirondacker, August 20, 2019, 07:16:09 AM
adirondacker
To all you portable sawmill owners with v-belts running under saw blades.....what do you use to clean the sawdust that's builds up on top of v-belt....obviously it needs to be cleaned... especially problem on sawing pine. My question is....do you use a toothbrush or what? Obviously not any type of wire...but the sawdust can become quite "tacky". I know there are some pretty sharp operators out there.
Crusarius
I just use a hand wire brush. Get the blade spinning then hold the wire brush against the belt. Doesn't take much time or effort. so far I cannot see any damage caused by it.
69bronco
I use a piece of broken blade as a scraper, everytime I change blades.
Ed_K
 I use a broken sticker so I'm not close to the blade while it turning.
Ed K
ladylake
 I never clean mine with no bad results.   Steve
Woodpecker52
just mount bristle brushes like a regular bandsaw does!  I never have to clean my v belts ever!
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Crusarius
That is definitely on my ever growing list of things to do. It is the little details that really make building a mill very time consuming.
WV Sawmiller
   The last time I serviced my mill and flip flopped the drive and idler belts positions I took the belts over to the wire wheel on my 6" grinder and cleaned them up. You have to be real careful to just lightly kiss the tips of the brush against the belt surface but it sure knocks the old pine sap and such off quick and in a hurry.
Tom the Sawyer
My TK B20 came with phenolic scrapers flexed on the wheels to scrap off the dust before it accumulates.  They work fine, and are quick to replace when they wear down, or get snapped off when a blade breaks.  A properly adjusted deflector on the drive side guide roller significantly reduces the potential for dust packing on the wheels.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Nebraska
I just lightly push the edge of my pocket knife and turn them when I change the blade seems to work fine.
John S
I use a small scraper each time I change a blade (usually).
2018 LT40HDG38 Wide
ladylake
Quote from: Tom the Sawyer on August 20, 2019, 04:09:31 PMA properly adjusted deflector on the drive side guide roller significantly reduces the potential for dust packing on the wheels.
 That's what I use.  Steve
