Push Start
Started by TimW, November 14, 2019, 08:07:04 AM
TimW
My LT40 Wide Diesel has only 50 hours on it and to get the carriage moving into the cut, I have to give it a shove.  Sometimes I push a little while in the cut.  Especially on big logs.  Any idea what the problem is?
          hugs,  Brandi
Southside
Have you checked the drive belt tension on the fwd / rev motor down by the chain?
White Oak Meadows
terrifictimbersllc
Does the head return quickly?
Unhook a motor lead and see if the head moves freely just pushing it with no log?
If so, take the power feed belt cover off, check belt tension (7# at 1/8 deflection on my old mill), see if loose and watch what happens with the motor revolution as you turn up the feed, anything odd there?
TimW
Quote from: Southside on November 14, 2019, 08:09:39 AM
Drive belt tension?  What drive belt?  I was under the impression the drive motor would have a sprocket on it, to contact the chain.
hugs,  Brandi
Southside
Take the black cover off, the motor drives a pulley which is what is geared to the chain.
White Oak Meadows
TimW
Quote from: Southside on November 14, 2019, 08:19:53 AM
Oh sweet.  That makes sense.  I will look at that tension tomorrow.
Thanks so much.
hugs,  Brandi
Southside
My phone won't let me post a link but @richieway put a video in the sawmill section just the other day doing maintenance on his Lt 40, he adjusts his in the video.
White Oak Meadows
John S
At 50 hours (and every 50 hours after) there is a complete service schedule that should be done.  It includes references in the manual where to find the procedures for adjusting belt and chain tensions, among other maintenance routines.
2018 LT40HDG38 Wide
Southside
Absolutely, you really should check the band drive belt tension now too, you need to stay on top of that especially with a wide mill as cut quality will suffer if it's loose. Make sure you use the calibration gauge when checking it as too tight and you can destroy your engine.
White Oak Meadows
Chuck White
TimW
Quote from: Southside on November 14, 2019, 08:56:47 AM
I think I can figure it out.  Thanks.
hugs,  Brandi
TimW
Quote from: John S on November 14, 2019, 09:21:20 AM
I am aware of that and planning it all this weekend or next weekend.  I went through the manual page by page when I got the mill.  But I slept since then. :D
I have been an aircraft mechanic for 41 years. 27 years with a major airline. smiley_book2_page   I know all that and asked here just for a heads up. ;)
I was thinking with all the bells and whistles on the mill , that it might be something I can't see, like electronic stuff with protons and electrons. ???  I'm not that swift with electronics. smiley_dunce  I just know enough to get me in trouble. :-[
hugs,  Brandi
TimW
Quote from: Chuck White on November 14, 2019, 02:17:30 PM
This is the video @Southside mentioned!
http://forestryforum.com/board/index.php?topic=108354.0
Thanks Chuck.  I will check it out later this weekend.  Now, it's off to work I go.
hugs, Brandi
barbender
Simple stuff first, always. My head won't move at all at the moment, due to the fact that it's about 50° colder than last time I used it. Something is frozen on the shaft on the head travel, or something😑😁 I'm waiting for Saturday when it is supposed to get above 32° and the problem will hopefully solve itself👍👍
SawyerTed
I was having problems with inconsistent cutting speeds.  Sort of like sawing into hard and soft spots in the log.  Turned out that my drive chain was in need of lubrication.  The chain was binding and wouldn't feed through the sprockets smoothly due to rust.  A good dose of ATF and several trips up and down the rails has solved that problem.
Sheepkeeper
Quote from: barbender on November 14, 2019, 08:27:30 PM
Most likely wet sawdust inside the drive belt cover freezing the belt/pulley into a stationary position. Been there - done that  :D
The hurry-er I go the behind-er I get.
TimW
Quote from: SawyerTed on November 14, 2019, 08:40:13 PM
Thanks Ted.  ATF is applied regularly, along with the rails.  I then cover the rails with flexible automotive split conduit.
hugs,  Brandi
YellowHammer
I agree, the fwd/rev drive belt is most likely the problem.  The belt is a rather small v belt and if it's just a little loose it  means lots of lost grip.
Sometimes they will slip enough to wear the side of the V off so the belt starts to incorrectly bear on the bottom of the pulley, instead of its tapered sides, and the only way to get it to grip is to overtighten it. So I always kept a spare for a quick replacement.  Very easy adjustment and fix.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
TimW
I adjusted the belt tension.  Works like new now.  Thanks All.
But the adjustment on the motor slots is about max out.  I need to buy a new belt and keep this one as backup.
  hugs,  Brandi
WV Sawmiller
   Yes, keep a new belt ready. They are cheap and easy to install. Glad that was all it took. I finished a customer's job one time by pushing my mill the last log or two by hand to finish then found it was just the loose belt and 5 minutes or less to fix.
TimW
At $6 each, I bought two belts.
hugs,  Brandi
