Price, 8/4 red oak trailer decking
Started by fluidpowerpro, May 10, 2022, 03:52:25 PM
fluidpowerpro
What's the going rate for 8/4 red oak trailer decking. Air dried.
Change is hard....
barbender
Up here I've been at $1.50 a board foot on red oak decking, green off the mill.
moodnacreek
$1.50 off sticks. $2,00 for w/o if I have it.
Oddman
fluidpowerpro
Thanks guys. 1.50 is what I was thinking so that confirms it.
Change is hard....
customsawyer
I'm going to guess my logs are a bit higher than most. Mine starts at $2.50 up to 8" wide and 16' long. Wider or longer is higher. This is green off the mill.
www.thecustomsawyer.com
alecs
What is the most useful size aside from the 8/4 for trailer decking?  I am expecting to get some white oak for a project here but will have extra and might cut it up for trailer deck to sell.  The log is 10'+ long and 22" dia.  Is 6" wide the standard?  8"?  Is 10' too short to be useful, assuming the deck planks run lengthwise?
firefighter ontheside
I would think most 10' trailers don't need 8/4 decking.  I sold 4/4 green white oak to a guy for a 10' trailer.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Jim_Rogers
Quote from: alecs on May 11, 2022, 07:59:04 AM
When I sold trailer decking in Northern MA, I made them all different sizes and thickness depending on what the customer needed for his trailer.
My advice to you would be to cut those logs into the largest cant you can get and just set them aside until you get an order. Then bring them back to the mill and make the planks you'll need to fill the order.
Good luck with your projects.
Jim Rogers
barbender
Treated radius edged decking (5/4 x 6").. good product for small trailers. Untreated of that size/thickness in rough-sawn should also work good. Size of knots most limiting factor.
