Sawdust Removal
Started by Wintergreen Mountain, May 13, 2020, 08:08:52 PM
  I was shoveling saw dust along the discharge side of my mill today. I took a few second break and looked around the yard. Up by the camper I spotted my snow blower.
   I started thinking! Witch usually ends up breaking something when I think like that. So I go over to the snow blower, get it running, and take it over to the mill. Within 2 minuets and three passes I had the sawdust blown past the end of the mill where I can scrape it up  my tractor bucket. I think with a little practice I can do it cleaner and faster.
   Also it exercises  the snow blower during the summer.
   Leon
1920 Ford 4x4 tractor, forks & bucket. 2010 36" Turner Mills band mill. Cat-Claw blade sharpener. Cat-Claw Dual Tooth Setter. Cat D3 crawler dozer. Cat 215c excavator, Ford L9000 dump truck. Gardner Denver 190 portable air compressor. KatoLight 40Kw trailer mounted gen set. Baker M412 4-head planer.
doc henderson
jmouton
that is pretty kool,,,kinda sounds like something that would happen in the south,,,,  if they had snow blowers there,, ;D ;D ;D
                                                           jim
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
frazman
Right on, right on, right on , Excellent on your part. Way to go.
Sheepkeeper
If it's a walk behind snowblower be careful. Most of the ones I've seen do not have an air filter on them and you could end up sucking sawdust into the engine.
The hurry-er I go the behind-er I get.
Woodpecker52
In the South all we could do is bush hog it.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
    Sheepkeeper;
   Thanks for the air cleaner Tip.    It only has about 6 hours on it and I have never had the intake cover off. I'll check it in the morning.
Leon
Ljohnsaw
Hmm, great minds think alike ;)  I have about 2 feet of sawdust behind my mill (30'+) and was not looking forward to shoveling it out.  So I bought this:
  Its a 40v rechargeable unit.  Going to try it out real soon.
John Sawicky
Sawmill Man
Quote from: Woodpecker52 on May 13, 2020, 11:21:49 PM
Or back an airboat up to the pile, sawdust and some slabs gone
"I could have sworn I went over that one with the metal detector".
Sixacresand
Wonder how it handles pieces of bark and wood splinters??
Ljohnsaw
All the big bark chunks get picked up after every log.  Sometime we pop the bark off before we cut.  My sawdust pile should be fairly clean.  The "blade" on the show blower is made of rubber and is like a section of a semi mud flap.
John Sawicky
Sixacreasand;
   I pick most of the bark and chips out as I saw. It did pass some 2 to 4 inch chunks trough easily.
                36 inch Troy Bilt
Sawmill Man;
      Have you tried that power blower yet and if so how did it work?
   Leon
Sawmill Man
Quote from: Wintergreen Mountain on May 15, 2020, 03:30:56 PM
Sawmill Man;
Oh yes i use it all the time especially in the summer. It evens serves as an outdoor airconditioner and an aid in burning slab piles. The only downside is the help complains of sawdust in their eyes. Wish i had one 30 yrs ago. I will let the sawdust build up and make a video sometime
