Receiver Hitch Post Vise
Started by ~smokey~, October 06, 2020, 01:37:53 AM
~smokey~
Seems like an odd subject for Health and Safety but since this involves both my health and safety I hope it's ok to post this here.
Due to an injury I built this simple post vise to hold my chainsaw for easier starting, it slides into the receiver hitch on my truck bumper and has a large jaw capacity so can be used for holding many other things. The parts include a 14" long screw and nut from an old scissor jack, a pair of 17" long 2x4s along with some square steel tubing. I'm hoping this might help others to stay safe !
~smokey~
One of my favorite kinds of steel to work with are these 1/8th" wall thickness telescoping posts are called Telespar, they come with or without 7/16" holes spaced 1 inch apart, the ones pictured are 1¾" O.D.  and 2" O.D   if you want strength without too much weight these work great.
~smokey~
The smaller 1¾" O.D piece of tubing has a larger hole drilled in the center for the screw to pass through, the nut from the scissor jack is retained inside the tubing using the original bolts, the tubing is bolted to the 2x4 using regular hex bolts or carriage bolts
~smokey~
Two pieces of steel are cut off the vertical tubing so the sides can be bolted to the horizontal tube that slides into the receiver hitch
~smokey~
The 2x4s can be used just as they are for holding things, or various jaws made from steel, rubber, plastic, aluminum etc, pictured I've used two plywood blocks to hold the chainsaw bar and to keep the chain from contacting the 2x4s
~smokey~
A ¼" thick by 18" long by 4"x4" piece of aluminum angle iron is used as a removable shelf to place the chainsaw on so aligning the bar in the vise jaws is easier
~smokey~
A small hinged rod fits into the post vise to support the weight of the chainsaw
~smokey~
This slotted bracket mounts the shelf to the post vise
Crusarius
Pretty nice setup. I could use that on the back of my tractor.
samandothers
Very creative!  Necessity is the mother of invention.
Sedgehammer
I use a vice thats bolted to a plate that's welded to sq tubing that's shaped like an 'L' with the short leg going into the trucks receiver. Welded is preferred over bolts, as no movement.
Necessity is the engine of drive
barbender
That's very resourceful, and should double as a filing vice as well👍
Tacotodd
barbender, my thoughts exactly, plus useful for saw carb tuning for a third hand.
Trying harder everyday.
~smokey~
Quote from: Crusarius on October 06, 2020, 06:00:41 AM
~smokey~
Quote from: samandothers on October 06, 2020, 06:39:49 AM
That's the truth, I'm lucky I have a big pile of parts kicking around the place !
~smokey~
Quote from: Sedgehammer on October 06, 2020, 09:53:56 AM
My first thought was to use a bench vice but the larger capacity of a post vise worked better for my needs
~smokey~
Quote from: barbender on October 06, 2020, 12:06:04 PM
Thanks, should come in handy for holding all sorts of things
~smokey~
Quote from: Tacotodd on October 06, 2020, 12:25:18 PM
Carb tuning that's a good idea, helps if the saw is not vibrating all over of the place !
