371 372 372xtorque
Started by Firewoodjoe, September 24, 2020, 07:53:50 PM
Firewoodjoe
Well I've got them all. A pile of them. Most just need minor stuff. Coil clutch brake band. Stuff like that. I have one xtorque that I'm sure needs rebuilt. Sucking air hard. Will just rev high then die. I have new in the box saws but I'd really like to fix all these because it's a bad habit and a waste of money to just keep piling them up. My question is is it worth buying those kit/part saws? Or stick with oem? Then will the clutch assembly and oil pump fit from the xtorque to the older saws? This would make it quicker for me.
steele109
Hi everything on the clutch side will work on 365,371,372. I have several kit saws and they run good but given the choice I would stick with oem. Everything on a xtorqe except the air filter,intake,carb,boot, cylinder and piston will interchange with the original.
