Band saw engine find
Started by Vautour, October 02, 2020, 03:52:28 AM
Vautour
Picked up this generac generator on the curbside for garbage... converted the fuel from propane to gas.               ....engine is 32hp with starter and looks like new..              .... total cost,  homemade intake with fittings $25....BOOM 8)
the Gospel is WANTED by the people in 52 Countries but made illegal by their Government
JoshNZ
That's a win alright. What will you do carry 9kg bottles around with your mill?
Vautour
@ JoshNZ... it has now been converted to gasoline for that reason to not carry those bottles..
JoshNZ
Oh haha. American gas not NZ gas  :D
ladylake
 What brand is it.  Those generator engines run at 1800 RPM most times, if it has 32hp at 1800 rpm it will have lots of torque.  Steve
sawguy21
That is likely a 3600 rpm engine from a standby generator, it will probably have a tapered shaft with no keyway so you will need to be creative.
RAYAR
Swapping out your engine already?
mobile manual mill (custom build) (mods & additions on-going)
Custom built auto band sharpener (currently under mods)
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans (432,500 Km) (laid up for engine repairs)
2007 Ranger 4X2, auto trans (185,000Km)
Vautour
@ladylake... not one marking on it so i don't know what brand it is.. has similarity's as a kohler command...                                         @sawguy21.... tks for that info... i had to cut the generator shaft to separate the two and that small stub stayed on the engine so it's not tapered any more and can see the end of the tapered shaft and will weld them together..        @   RAYAR.... i'v got two mills on the go... this engine goes on the smaller manual mill that i'm working on now...my bigger mill is on the back burner.
RAYAR
Quote from: Vautour on October 03, 2020, 02:17:06 AM @   RAYAR.... i'v got two mills on the go... this engine goes on the smaller manual mill that i'm working on now...my bigger mill is on the back burner.
Oh, I didn't know you started another mill unless this is the first mention of it, or did I miss your post about it?
Vautour
RAYAR ... i did mentioned building a smaller one about 7-8 months ago with scrap steel I've got at the shop... hopping not to break my budget of $200-$300 on this one :D...will post pics when near completion
jmouton
it came off a generator so it wont have side load on the bearings on the shaft , you will burn the bearings up quickly , dont ask how i know , but it was an oily mess and parts flying everywhere ,,,  no side load ,,
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
Gearbox
I used a generator motor on a box wood splitter . The taper on the shaft is the same as a morse taper on a drill bit or tail stock . Bore out a lov joy or pulley a little red loc tite  and a 3/8 bolt and washer it was good to go .
Vautour
@jmouton .. tks for pointing that out,i'll add a small shaft with pillar blocks and love joy to fix that problem ... Gearbox... good idea.... tks guys
Gearbox
Bore that lov joy a little under sized so the bolt will tighten up on the coupling .
Two Trax
Pretty sure this engine will be a Robin Subaru, or at least a joint venture between Generac and Robin.
Livin the dream!
firefighter ontheside
I've had 2 generac generators, one I still have.  Both always ran well as long as I didn't let it sit for long periods of time.  The carbs always got clogged, but thats my fault.  They both have/had generac motors.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
sawguy21
That is likely what he has, Subaru no longer builds air cooled stationary engines. If it is going to sit best to use Seafoam or a similar product in the gas, small engine carbs are not very forgiving
Vautour
Never heard of Robin Subaru before but did a little recherche and looking at pictures it does seems to be the maker,  have similar parts and location, oil filter, intake manifold,starter, etc
Two Trax
Quote from: sawguy21 on October 07, 2020, 11:12:31 AM
It is a fact that Robin Subaru disbanded operations and sold off various select engines to other manufacturers. For example Kubuta bought some of Robins models and are now manufacturing them.
Robin did in fact have a hand in building and designing these engines initially. Perhaps Generac bought that design as did Kubota and others and is now manufacturing the engine in house.
Robin Subaru built engines that rivaled Honda, I have 4 of them in various pieces of equipment including a single cylinder diesel in a generator. They are excellent, too bad that they decided to cease manufacturing.
Livin the dream!
