Farmi Winch 306?
Started by rweiss1110, February 27, 2020, 01:13:47 PM
rweiss1110
I have I believe to be a Farmi 306 winch and I'm looking for an owners/maintenance manual. I'm sure it needs grease or oil but where. also can anyone venture a guess what the J wire coming out the top of the winch cover is? I bought this rig used for $300.00, it was sitting in this guys hayloft for over 20 years he said since he used it. I have gone out in the woods and it hauls logs, just moans & groan alot.
47sawdust
Farmi Winches
These folks should be able to help.
I moan and groan a lot too,after a day in the woods.After all 20 years in the hay loft was  pretty soft.
Welcome to the forum
Mick
Quote from: rweiss1110 on February 27, 2020, 01:13:47 PM
I have no idea where the top of the winch cover is or the J wire. I doubt I could help, but would like to know. Maybe others too?
$300      Good deal!!!!
g_man
I don't know about that vintage but the newer Farmi winches only require a little light oil on the control rope pulleys, brake latch lever, and eccentric clutch engagement rings. All the bearings are sealed. They have a warning about over oiling as it can migrate to the clutch and it says specifically not to oil or grease the no oil gear chain for that reason. I would oil the obvious places. On mine I grease the cable pulley surfaces where they swing too. They screech if I don't.
You got a real good deal !! Today I saw a Igland 4501 in good shape for $1500 on VT CL and thought that would make a good deal for someone but yours beats that.
gg
rweiss1110
Thanks all, I reached out to northeast implement and they sent me a pdf  on my rig. And let me say it answered all my questions, and some I didn't even know to ask. So lets pull some logs!
Lostinmn
If the moaning and groaning is to much for you... I'd gladly give you 300 bucks so you have some peace and quiet again  :) :D ;D
You got a great deal!!
