Raining and freezing here, bet there's going to be a lot without power tonight
Started by Sedgehammer, October 26, 2020, 03:16:46 PM
Sedgehammer
Quote from: Walnut Beast on October 28, 2020, 03:48:51 AM
Hang in there. Do you have a generator?
Thanks, yeah we're good. Generators running, have plenty of gas and food. It's weird though, look outside and none of the neighbors lights are on and ours are. We drove around a bit and all dark.
Necessity is the engine of drive
Sedgehammer
still raining here. Feel bad for the crews working in this crap. Cold and wet. They are swapping crews out to get warm, dry and rest, then sending them back out.
samandothers
Quote from: Sedgehammer on October 28, 2020, 09:48:47 AM
Yes, also hard to be as productive and safe at night scouting and working.  Company I worked for moved to working day light then rest and do it over.  There were crews at night to handle some things but not as many.
Hope it gets back to normal soon!
goose63
The last time the power went out Ibought this the best $2500 I ever spent hook the tractor up and power
The power copmany said it wont feed back down the line I don't trust it so I shut the pole off
goose
thank you to all the vets
Sedgehammer
Quote from: goose63 on October 28, 2020, 01:42:07 PM
Looking at a PTO style, as our current generator really isn't big enough. Had a PTO style growing up. I need a 35kw.
goose63
goose
Sedgehammer
Yup. Tractor can power it vs another motor sitting around. I'd need a 55 HP tractor for 35kW.
samandothers
Quote from: Sedgehammer on October 28, 2020, 01:49:43 PM
:o
That's quite a bit!
We plan a whole house unit for our house build and could probably use a smaller one than we're doing if we'd not run certain stuff.  Though it is good to know you can run whatever you may need/want.
Sedgehammer
Sedgehammer
5,290 still without power including us. No time frame on when it'll be on.
samandothers
That's rough!  Glad you have some generation to help.  Hope temperature has moderated a bit.
Sedgehammer
Yeah, it's much warmer. There was like 300k total without in the metro. Not sure how many still without  on OG&E.
Sedgehammer
We were lit Saturday afternoon. Nice having it back on.
The local hardware store saved me a pole saw attachment for my power unit. He said he figured we'd need one, so he pulled it from his stock..... :laugh:
Don P
We just came back on, yesterday and today was high winds that knocked out power all around here. I saw one cluster of trucks working on a 3phase line restringing a leg, usually they are well cleared. I worked on my wifes car in a friends garage where we have been doing a tranny swap. We had the woodstove going which is great but had to wear headlamps the whole time  :D. His came back on right after I left, we came on about 4 hrs later. That should be about it, we are the end of a remote line so low priority.
Sedgehammer
Quote from: Don P on November 02, 2020, 09:17:28 PM
doing mechanic work with headlamps, fun...... leastwise you had heat, that sure helps.
We are the furthest leg away from the power station as well.
Spent all day yesterday with the pole saw. will be all day today and tomorrow also.
FEMA is in on the clean up. They opened bids up on Friday for 6 hours and accepted 5 bids. Here they are;
1 = $3,000 per ton
2 = $1,000 per ton
2 = $500 per ton
The $3,000 per ton is a large asphalt plant. They have their own quint axle dump trucks and will be using loaders with grapple buckets. they should make around $6 million for 2 weeks work. Loose brush is about 250 lbs a yard. 25 yard dump truck is about $6,200......
here typically demolition clean up pays about $100 a ton......
GRANITEstateMP
are you saying they went with the highest bid, not the cheapest?  ???
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
Sedgehammer
Quote from: GRANITEstateMP on November 03, 2020, 06:10:19 PM
They went with them all as dumb as that is. i was told it's because they need it done asap and that's fine, what isn't fine is that when they saw the huge differences they didn't get the 3k one to lower it.
Sedgehammer
Spoke with my electrician friend who lives in the city. He's still without power. Many in the city he said were without still. Yikes.
Right now we have about a 200 yards of tree branches out at the road.
I'm thinking of cutting our 25 cedars that line our property along the private road. The city said they will haul off all waste, so an easy time to do it. They are under the power lines and they get cut back every 5 years or so and look goofy, then with all this ice, they are now trimmed up about 12' and some higher off the ground. I think I'll replace them with either different flowering shrubs that will blossom all summer and something like Japanese maples that have very pretty foliage all summer or combos of each. Something that is at least 8' tall, but under 20'
