Galvanized/corrugated metal below board n batten siding
Started by Sedgehammer, March 07, 2021, 09:54:19 AM
Sedgehammer
Anyone have - pics - experiences - violent reactions - suggestions - on doing it?
My wife asked about it and I kinda maybe think it wood look nice actually. Plus it wouldn't have that possible stain look at the bottom, although I prefer a dark stain vs a clearer one.  It wood break the walls up some, since they are 20', which is too tall really, but I don't really like change the roof slope look where they meet for a lean to.
Necessity is the engine of drive
Sedgehammer
Took me a long time to kinda get a pic that shows what we are talking about
Our siding is darker and the metal won't go that high. Maybe 36", plus our boards are 12"
gspren
I would do something different with where the b&b stops above the metal, you can see it stays wet. Maybe get rid of the horizontal board and cut the b&b at an angle so it drips off. B&B would need spaced out to overlap the metal maybe.
I asked a member about what he put on the bottom of a shop? he built. Was just like what you want. I myself would have the boards over hang the steel.
Sedgehammer
Quote from: gspren on March 07, 2021, 07:03:10 PM
No horizontal board on bottom. That's just not a good idea. Agreed on angle.
Not sure on what you mean b&b being spaced out.
@thecfarm can't really do over, but I wood bend a piece of galvanized like an a flat 'z' to go over the corrugated and up behind the b&b. Wood have a bent over front edge like 'j' has
Bruno of NH
I like the look and it's a great idea.
I would use z flashing that matches the metal and stop the wood at that.
No horizontal board.
Crusarius
can always run the steel in the horizontal direction and just run the b&b over the edge of the steel with the angle on the wood to allow for drip.
Or you remove/ flatten the top ridge and screw everything tight to the wall.
Sedgehammer
Quote from: Crusarius on March 08, 2021, 05:53:03 PM
Negatory ghost rider on the horizontal
I'll run some z over the top. Then run wood 1/4" from it with an angel cut on the back side of the board n batten
mike_belben
Ive used it inside my shack as wainscoting behind the stove to reduce the wall temp.
Praise The Lord
reride82
Sedgehammer,
I like that look, and 36" should work depending on your eaves. The shorter the eave, the higher I'd take the corrugated tin. With the Z trim and a bevel on the bottom of the boards to shed water I don't see a problem with it.
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Sedgehammer
Quote from: mike_belben on March 08, 2021, 11:20:02 PM
My man cave has it in the kitchen area above the cabinets and on the walls. That kind was the thin shiny stuff from home depot. I don't really like that, but at the time had no other supplier. I now have found a local supplier of the real older looking stuff and is thicker.
Raider Bill
I used it behind my wood stove in Tenn.
Also have the 5 bend as a ceiling and the ripple on one wall in my sports room in Florida.
The First 72 years of childhood is always the hardest.
My advice on aging gracefully... ride fast bikes and date faster women, drink good tequila, practice your draw daily, be honest and fair in your dealings, but suffer not fools. Eat a hearty breakfast, and remember, ALL politicians are crooks.
47sawdust
Here in Vermont it would be a problem.
Snow build up and splash back from the eaves will cause it rust.
Mick
