left hand vs right hand
Started by jmouton, March 30, 2021, 04:01:08 PM
jmouton
so i know nothing about circle mills ,just bandsaws ,,  what does it mean if its right handed or left handed,,
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
Brian_Rhoad
Right hand manual circular mill the log passes the sawyer on the right side. Left hand is the opposite. If the sawyer is sitting in a sawyer cab, right hand would be the log passing the saw from right to left.
moodnacreek
The 'hand' of a sawmill has to do with where the logs come in and the lumber goes out. Or you can put 2, l/h and r/h to- gether  and merge the lumber coming off both, [a mill not far from here is doing that]   And in the beginning it depended on which side of the river you where on!
