Western larch my new least favorite
Started by Crossroads, September 27, 2021, 12:00:47 AM
hacknchop
I tink it name come from de same guy he ask me to cut im some 2x4 an inch tick.
Often wrong never indoubt
Crossroads
Quote from: hacknchop on September 29, 2021, 10:12:45 PM
That'll make ya scratch your head
donbj
Quote from: Crossroads on September 29, 2021, 09:42:01 PM
Quote from: donbj on September 29, 2021, 09:21:03 PM
Quote from: JRWoodchuck on September 29, 2021, 10:14:45 AM
Gotta educate those people that we don't have Tamarack we have Western Larch. Like we don't have 'Red Fir' it's Doug Fir.
And there's Jack Pine, whos proper name is Lodgepole Pine, Bull Pine is Yellow Pine.
I had someone telling me the other day that jack pine and black pine are the same. I'd never heard of black pine 🤷‍♂️
It's black pine after the fire goes through, :)
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
Satamax
Quote from: Crossroads on September 28, 2021, 10:40:36 PM
Quote from: donbj on September 28, 2021, 12:46:16 AM
Quote from: Crossroads on September 27, 2021, 09:44:23 PM
Yeah these were the butt cuts. I've varying results with it even with the second and third logs in the past. At least with the bigger logs. I run straight diesel in my lube system and even with flooding the cut, it still has builds up with pitch. If I clean the blade before each cut with my knife, I at least will make a straight cut for 8-10'. I'm not familiar with the eastern larch. The western larch is also referred to as tamarack. As far as I'm concerned it can all go to firewood lol as it does make great firewood.
It's actually eastern larch that is referred to as tamarack. I'm curious, is this wood coming off a steep slope or other situation that changes things? I know slope trees can have a lot of stress in the butt sections causing what you are experiencing.
That's interesting, hardly anyone calls it western larch, most people around here call it Tamarack. As for we're the trees came from, I don't know, they were trucked in is all I know. I didn't see any of the normal signs of stress in the wood like lifting, bowing or pulling. The only thing I had was pitch buildup. Interesting thing though, the last blade I ran on Saturday was only on the mill for a few cuts and had quite a bit of buildup on it when I pulled it off and coiled it up. I put it in the pickup last night to run on today's job. It rained last night and all of the buildup was broke down and whipped off easily. So, maybe diesel isn't the best thing to use on tamarack?
Quote from: wisconsitom on September 28, 2021, 09:13:03 AM
I was stripping bark off a few hybrid larch poles cut last winter.  This stripping was early this summer.  The wood/bark was still so juicy I had flecks of sap all over my face and glasses.  Really wet stuff.  Smelled good too.
Too bad I never got to the other 400 or so that are still laying in piles.  Wonder when/how I'll get to all of that, especially given I can thin an equal number of stems out of those same stands this coming winter!
Larch is rich in a polysaccharide (like a whole bunch of sugar molecules chemically hooked together) called arabino-galactan.  This stuff also makes the wood less suitable for pulping, and a given amount of larch pulpwood must be mixed with a given amount of other wood types for that process to work.  This same substance is extracted and used as a dietary health aid for the human gut.  It acts as a soluble fiber.  I use it and think it beneficial.
And yes, this substance is concentrated near the butt.
Well, sugars cannot be diluted by diesel. So my mix of water, washing up liquid and diesel might function better because it dilutes sugars as well as lubricating the blade with the diesel.
HTH.
Crossroads
I believe your right, I might put some water in the mix next time.
Brucer
Larix Occidentalis - aka Western Larch:
When it behaves, it's a dream to saw -- cuts like butter :).
When it misbehaves it's a pain in the butt :(.
You never know for sure what you've got until it starts to dry ::).
I use 50/50 water and windshield washer fluid, and I crank the water valve wide open. Literally flood the blade.
With a difficult log (butt end, 24" diameter) I once clamped a 6' length of Western Red Cedar onto my extension. At the end of the cut I'd keep the carriage moving until I reached the Cedar, then I'd make a 3-4" cut to clean off the blade.
I've lost about 1/4 of the Larch I've sawn due to ring shake. I can spot ring shake in D-Fir, WRC, & pine logs, but could never see it in Larch. It would show up after the wood started shrinking.
I've only sawn other people's Larch, with lots of warning about what could happen.
Bruce    LT40HDG28 bandsaw
mapleack
Crossroads, I use lots of pinesol and water cutting the larch we have here in Pennsylvania.
Norwood LM2000
JDowns71
Crossroads
I used quite a bit of pinesol in my water before I went to straight diesel. Looks like I may be going back to it when larch is involved.
Thank you for the article, definitely a good read!
wisconsitom
Yup thanks for that, JDowns.  Goes to show the issues associated with drying the stuff, which I've always heard could be challenging.
Larch wood can be a great product, but the catch-22 is this;  Will mills do the special setup for sawing and drying larch, knowing the supply is intermittent and the species less well-known than many others.....and will land owners go heavy into planting this species knowing most mills are not set up to handle it?
In all other respects, it's smooth sailing! lol
Ask me about hybrid larch!
wisconsitom
Randy d, if you're still here....what are you guys sawing your tamarack into?
barbender
Before I started working in the woods, I understand the local Potlatch stud mill was running some tamarack just trying to get enough wood supply. As I've said before, I've sawn tamarack that was great, and tamarack that was horrible. It would be hard for them to make a spec on a commercial scale that would prevent them from getting the misbehaving stuff. For instance, their current spec on pine bolts would be something like " 6" min, 20" max, no flares, rot or large open knots and well trimmed". Kind of hard to spec a max taper or no left hand grain. On one job a couple of years ago, we cut a patch of tamarack that had a lot of bolts, which were sorted for the pallet mill. One of the trucks somehow got it confused with Jack Pine (they were good sized, 12-16" bolts) and hauled it to Potlatch. They must've made a good Jack Pine impersonation, because they took it at the mill as such and ran her through. They didn't catch it until it made it to the graders😂 This batch was nice stuff and went through the mill great they said, and employees there were going to buy it as it turned out so nice, apparently. So no harm, no foul🤷‍♂️😊
Satamax
It, it's quite amusing, here we would like to cut something else from time to time.
Most of what grows here is larch.  (larix deciua) On the italian side of the border(sansicario, for example) They have something slightly different. The larches have falling "branchelets"  (is that a word in english?)
Well the main stem of the branch is on top, and all the little stems growing from it, are falling, a bit like a willow. That's weird for me.
Anyway, i quite like the larch. I work with local, russian and austrian stuff.
Here's two pics of what i am doing with the stuff i milled at the begining of july.
