I’m having a no start situation!
Started by HemlockKing, July 08, 2021, 06:39:01 PM
HemlockKing
I tried nothing and I'm all out of ideas! What could be the issue?
:D
Have a couple other abandonments too on this land.
A1
Tacotodd
Trying harder everyday.
HemlockKing
Quote from: Tacotodd on July 08, 2021, 06:57:27 PM
Did you try a lighter?   :D ;D
:D There may have been a sparking of some sorts there, but nothing strong enough to get that dang Chevy to start and drive me off to space!  :D
A1
Tacotodd
Well... stupid_smiley
Just sayin!  ;)
Not intended to be at you, but with you.
Keep us updated on the situation reports (sitrep)
HemlockKing
 This one might be gone though lol . Poor toyo.
A1
HemlockKing
There's some good steel in that seat though, wire and frame steel rod
A1
Old Greenhorn
Maybe the license plates are loose? That job I just finished had so many vehicles and implements I couldn't count them, if I had started taking pictures I would have never gotten anything done. But this one caught my eye because it looked like it just needed a tuneup (and an engine, and some tree work).
HemlockKing
Quote from: Old Greenhorn on July 08, 2021, 07:29:15 PM
Now that's a "eco-powered" car! A v- TREE(v8, vtree, my lame joke)   :D
Hopefully it's left there. I'm gonna be cleaning up a lot of the junk here but there are a a couple I wanna leave, one being The blue chev
A1
HemlockKing
Fertilized with old conventional oils and rust it's whole life that tree lol
A1
btulloh
HM126
moodnacreek
Hilltop366
I think this one has been converted to manual timing advance, you have to retard the timing to start and run at low rpm (put the acorns close to the squirrels) but as you want to accelerate you need to advance the timing (move the acorns further from the squirrels).
Southside
Security system has locked out the ignition due to the radio being removed - happens all the time.
White Oak Meadows
mike_belben
Quote from: btulloh on July 08, 2021, 08:02:25 PM
I would check the timing.
Oh its definitely bad timing.  About 35 years out of wack.
Praise The Lord
Mooseherder
sawguy21
He doesn't want to dwell on this too long, times a'wastin. smiley_horserider
Tacotodd
I'm SO glad that my doorless Taco runs EXTREMELY well! I was just in it running in town today. And not one popo said a thing. I guess had hands full with other issues, even the ones sitting PERFECTLY still :D.
What can I say, I'm blessed enough to make sure that ALL of my ducks are in a row and 100% on the up & up.
Like Mel Brooks said in one of his movies, "it's good to be da king", even though "I" couldn't find 2 nickles to rub together  :laugh:.  Oh well, not my problem, but they all realize that I'm doing everything right when they see me ::)
alan gage
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
HemlockKing
Quote from: alan gage on July 09, 2021, 09:30:45 AM
There's no ignition key.
Alan
Finally someone found my problem! I was thinking this would have been the first reply lol with all the wise guys here
A1
HemlockKing
Thanks for inquires fellas, found the issue, blown motor mounts obviously. Motor is tilted back a bit.
A1
HemlockKing
 Not sure what I'm gonna use these axles for, but that's some good high carbon steel right there lol
A1
21incher
You have to add lead to the fuel to keep old ones like that running  :P.
Old Greenhorn
Quote from: HemlockKing on July 09, 2021, 06:15:16 PM
Well, the hard work is done now, you found the problem. Looks like an easy fix.
moodnacreek
Quote from: mike_belben on July 08, 2021, 10:48:45 PM
It's the gas, If you would buy high test  you could put it back where it belongs. Also those uniset points where never any good.
