A little guidance
Started by wink, October 31, 2021, 05:18:43 PM
wink
 I bought a new Circular saw about 8 years ago to put on 1956 lane mill turns out it needed 3/ 16 lead to run cool and cut good . Upgraded mills in September 1985 lane used same blade 3/16 again  . Sawed some pine and some hemlock worked great sawed a few spruce and then blade started to cut into the log . Sharpend the teeth with my dexter guide didn't help installed new bits didn't help question is did I lose tension or would a blade need less lead that quick . 🤷‍♂️ any other ideas
barbender
Well I see it was spruce you had problems with. Spruce sawing headaches aren't just for bandmill guys, some spruce logs just aren't fit for sawing🤷‍♂️
Ventryjr
What model lane do you have?
-2x belsaw m14s and a Lane circle mill.
wink
I think your correct about the log I had issues before with spruce but this is the worst I'm going to make the rest of it firewood and try another hemlock to see what happens.  Thanks
Quote from: Ventryjr on November 01, 2021, 05:59:27 AM
My old one was a #2  this one used to have a tag on it but gone I haven't been able to identify by finding another  one the same . I was told 1985 its electric over hydraulic  with a cab🤷‍♂️
