Engine swap
Started by vatkins, August 21, 2023, 12:53:13 PM
vatkins
Hey guys, been awhile since I've posted. I'm doing an engine swap in the Clark 664B. Out with the 353 Detriot and in with a 4b Cummins. My question is does anyone know what I need for bellhousing and the flywheel to connect the Clark C272 88 tranny to the Cummins 4b ? I've seen 664's with a cummins so I know it's possible! I'll try to post about the progress. Thanks in advance guys.
DanielW
I'm afraid I can't help on the bellhousing adapter, but let me know if you want to unload that 3-53 Detroit!
Satamax
Well, if nothing comes from someone in the know. I'v seen Websites with SAE bell housings "standards" i can't remember where, but they're out there. The cummins end shouldn't be too complicated to figure out.  If you can find the tranny's documentation, you should be able to figure it all out.
Understanding SAE Bellhousing and Flywheel Measurements - Seaboard Marine
SAE Housing and Flywheel Sizing Guides | Complete List
https://oemdynamics.com.au/wp-content/uploads/2016/04/09-PT5-engine-pump-and-motor-standards.pdf
SAE bell housings standards - Google Search
French CD4 sawmill. Mecalac digger, with grapple. Self moving hydraulic boom crane. And a Brimont TL80 CSA.
wrightk20
My 664b has a 4bt in it. I can certainly get you a part number for the bellowing. Kevin
