Martial arts
Started by menna_forest92, October 15, 2023, 07:52:05 PM
Walnut Beast
Right down the road. Do yourself a favor Study this website and look for a place in your area like this place and you can get setup with proper protection and take some great training from people that are knowledgeable.
https://88tactical.com/
chet
Quote from: beenthere on November 05, 2023, 10:45:42 PM
Quoteforests are scenes of scary crimes, you know how many serial killers bury their victims in forests.
Don't know, and likely you do not know either
We actually had one here a few years ago. The dude cut up his victim and drove near a hundred miles to dump the remains in the Ottawa National forest.
SawyerTed
It's more likely a person needs self defense martial arts "in town" than in the forest.  More "scary" attacks, shootings and stabbings happen to people pumping gas, jogging or shopping etc than happen "in the forest."
Most rural crimes are property crimes -theft, breaking and entering and vandalism.
Frankly I'm more afraid of going out to eat in town than spending the night in the forest.
If self defense skills are on your mind, then learn them, practice them and be good with those skills.
The exact same advice goes for a firearm, learn to use it if you carry, practice and maintain your skills.
A lot of people get killed in the local Nat parks, but only one local murder I can remember. Vs hundreds killed by nature. Drown in flooded streams, fall off cliffs, get lost and die of hypothermia etc. And that's without ANY dangerous critters that could kill you.
There are lots of useful survival skills you should probably learn first before going into the wilderness.
Southside
The issue with any sort of grappling, striking, or other hand to hand, non-lethal, combat is that you need an exit strategy.  Your attacker isn't going to "tap out" and it is physically exhausting to restrain someone for any length of time.  Add in a physical size advantage, or drug issue, and I don't care how good your skill set is, you better be able to run fast and long to get away too. A weapon is a force multiplier.  I carry one when I leave the farm, and I am not of small stature and as I stated have had more than my share of training and experience, but I still carry a force multiplier.  I don't recommend pepper spray unless you take a full experience class with it and learn how to fight through a full face blast of it.  Yes, there is a physical reaction to the stuff, but for the most part it's psychological and that's actually a lot harder to overcome.  If you choose to carry it you better know that you can fight through it because if you use it, you will become impacted by it.
My advise is to find a firearm that you are comfortable with, and take a real training class or classes with it.  Not some macho prove yourself in a group of wanna be's  wearing "Crav-Maga" T shirts, pay for a one on one class with a pro.  Learn to shoot lying down, on your back, from a vehicle, weak handed, etc.  Also learn weapons retention, make sure you learn how to keep your own weapon.  Blading your body, blocking the weapon with your arm, knowing your surroundings, etc.
Many times you can de-escalate a situation by being confident, aware, and on top of a situation.  Predators look for weakness in their victims, skillfully backing out of a confrontation with confidence can get you distance and time, knowing you have a force multiplier available, should it be necessary, gives you another option if that fails.
White Oak Meadows
WV Sawmiller
  I actually have mixed feelings about chiming in here. I agree it is good to have an exit strategy but I am of the camp where if the bad guy is temporarily incapacitated keep pressing till he is no longer a threat. I can try to run but if he gets up he may catch me. If he's down don't let him up. Use any and all tools available as the force multiplier whether it is a stick, a board, a pipe, a rock, a bottle, a hand tool, caustic liquids, etc. Blind him, break bones so he can't walk or fight, crush windpipes, etc.
   I wholeheartedly subscribe to the theory "If you're involved in a fair fight, your tactics suck!?" This is not a competition with rules and umpires and such - it is survival. You didn't start it but you can't be afraid to finish it.
   I heard this as a true tale where a car jacker tried to pull an elderly lady from her vehicle and she shot him. There was a hearing and the judge/head investigator said they understood and agreed with her shooting him in self defense but asked "When you shot him he was down. Why did you shoot him 5 more times while he was on the ground?" The old lady replied "Because that's all the bullets my gun held."
barbender
 A friend of mine that did firearms instruction used to tell me, "a man might try to wound you, a woman will aim center mass and kill you!" I think women train to follow the training, and if you trained them to aim at the center of the target and keep pulling the trigger until the gun is empty, that's more than likely what they'll do😊
Peter Drouin
Be sure you know the law in your state on guns.
A Gock 43x 9mm is a good one to have.
A&P saw Mill LLC.
License NH softwood grader.
Southside
I know the last paragraph of yours is a joke WV, and that needs to be pointed out.  In legal terms you can go from justified force to unjustified in the blink of an eye.  Rules of engagement are different than civilian rules.  Force must be "reasonable" and in many cases "necessary" to stop a threat, dumping a mag won't be considered either if the answer is "I stopped when I ran out of ammo".  "I stopped when the threat stopped" is the correct answer.
White Oak Meadows
Several years ago we had a case here where the wife testified that she couldn't help herself and kept pulling the trigger.  The problem was that it was a single action pistol.
WV Sawmiller
    Joke? Not really.
    As a layman none of us could be expected to know how much force is needed to prevent an attacker from getting up and resuming his attack. I am too old to be worried about investigations, court dates or hearings or what other people think. My only thought is survival and I did not start the altercation.
    Remember we are assuming this is a one on one attack in an isolated area and "reasonable force" is very subjective and a relative term. The little lady was a senior citizen and less than half the size of her attacker. My upbringing, beliefs and training were different than many others.
   I am a really nice guy and will help anyone I can but I will not be abused or threatened. The goal is to destroy your enemies ability and desire to wage war against you. This is no different.
YellowHammer
My daughter is required to take basic self defense hand to hand, and hand to weapon training, and she has had to use it.  She's pretty good at it, also so also trains above and beyond workplace requirements.  However, help is always close at hand where she works (anybody have a guess?) and she uses it as a primary delaying tactic as she doesn't work in a place that's really a good place to permanently harm or kill people.
That's being said, if you consider that many attacks may come from multiple people and multiple directions, and that substantial training is required in any combat endeavor, my daughter does not hesitate to carry (not at work) and professionally train with a pistol.  She's quite good at it, and besides the pro training she gets, we practice when she comes over to visit.  We are currently working on the Center Axis Relock pistol technique.
Her favorite, if you can call it a favorite, hand to hand technique is Krav Maga, because it focuses on defense against weapons techniques vs bare hand to hand, and her favorite pistol is the Sig 365 SAS.  It's also mine too, at least this week.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
caveman
Quote from: WV Sawmiller on November 06, 2023, 10:13:37 PM"Because that's all the bullets my gun held."
Several years ago a local deputy and his K9 were killed during a traffic stop a block away from the high school that I worked at for 22 years.  Many of you may have heard of our county sheriff.  The most dangerous place is between him and the T.V. camera but he is a good guy and a one-liner king.  The suspect was shot multiple times when he was found a day or so after the initial traffic stop.
https://www.nbcnews.com/id/wbna15012086  Sheriff Grady Judd answering as to why the suspect was shot 68 times, "that's all the bullets we had".
Caveman
barbender
 I get where Southside is coming from, you don't know how a jury is going to come down. You don't want to be making statements that sound callous or indifferent to human life. You want your statements to line up with the fact that you feared for your life, which I hope you in fact did if you shot someone.
The very first statement that you make to law enforcement will be your defense and will follow you until the case is closed.  Choose your words carefully.
You felt that your life was threatened and you took the self defense measures to remove that threat.
Southside
The Sheriff in that case was talking to the press and had zero concern for criminal liability as he wasn't the shooter.  In this day and age the very real threat of even the most clear cut self defense case ending up in front of a grand jury is real.  Prosecutors don't want to be the ones to make the call, so they pass it onto the grand jury.  Anything you say can and will be used against you.
Not trying to dismiss your concerns WV, but as a guy who has been on all three sides of this coin I am just trying to let folks know how our system works and how it's different from the rules you had overseas.
White Oak Meadows
WV Sawmiller
   All three sides would be attacker, attackee and legal system. Right?
Southside
White Oak Meadows
