WM motor brushes
Started by delvis, October 22, 2014, 12:41:19 AM
Peter Drouin
And if you get the micro switch too close. The banging of the log on the mill will turn on the pump when you're not using them and run while your sawing and won't hear it,
Pump will be on all the time. Not good..
Brushes are easy to change, But only weir down halfway before you have to change them. I keep a bunch on hand.
A&P saw Mill LLC.
License NH softwood grader.
Chuck White
It could also be that the rod the microswitch is mounted on is slipping inside the microswitch clamp, thus becoming out of adjustment!
OlJarhead
Thanks guys.  I posted a very short vid of me pushing on the switch so you can hear it and then with everything working right after I kept moving a lever (to show that it eventually works) on my Old Jarhead thread ;)
Brucer
Quote from: OlJarhead on March 01, 2023, 01:00:21 PMOK, this has me scratching my head. If I read that right you checked them (how?) at 750hrs and only replaced at 2170? Or did the brushes at 750hrs and replaced the motor at 2170?
Sorry, I'm just catching up on forum stuff.
I could have been a little clearer on that. I checked the brushes every 750 hours by pulling them out of the motor and checking how much wear there was. At 2170 hours the mill was down with another problem so I decided to check the hydraulic pump brushes then instead of waiting for the regular 2250 hour inspection.
Bruce    LT40HDG28 bandsaw
OlJarhead
