John Deere guys
Started by rdobb13, August 24, 2022, 01:47:01 PM
rdobb13
@kiko, hey sir.  Getting a 478 code that is bringing the stop light and buzzer on.  It has some other codes that it's always had.  What should I look for?
rdobb13
Also codes 421, 343....they have been in for a while.
kiko
F421 Engine temp sensor or wiring short to ground
F343 Trans temp sensor issue
F478 pump control current . Check the two pin connector at the back of the injection pump.  Also check the connector at the ecu.  I have had to replace that connector with a pig tail many times.  You can purchase what you need to make a pig tail at most autoparts stores.  This is the Dorman part number.  The plug won't fit but you can remove the terminals and they will snap into the deere plug.
Could not get the camera to focus but you get idea
