When to turn temp up for sterilization
Started by JamieK, February 20, 2023, 02:44:18 PM
JamieK
Hey guys, im just about to finish a load in my l200m . Currently my dry bulb is set at 120° and wet bulb is at 98°. The average moisture of the lumber is at 12% and am at day 13. At what moisture do you guys start cranking the heat up for sterilization?
Wood-Mizer LT70 full line, BMS250, BMT100, Moffet M5,Nyle L200M, Lucas mill model 7 with slabbing attachment and planer attachment, Logosol PH360, 2017 Ford F450 Platinum
K-Guy
It depends on if it is softwood or hardwood,  for hardwood  most dry it 8% or less,  for softwood not below 10% or the wood becomes brittle and hard to machine.
Nyle Service Dept.
- D. Adams
JamieK
So if i crank it up to 140° at 8% after 48 hours my moisture should be in the target range. Is that correct?
JamieK
YellowHammer
I dry to 8% then increase the temp set point to 150°F and when that is reached, hold for 24 hours, compressor off, then let it go down slowly and it will end up at 7% and done.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
JamieK
Thank you guys, I sure appreciate your time
