Tenon cutter
Started by Larry, May 08, 2024, 10:21:02 PM
Larry
I have been making chairs, stools, and benches for a long time. I've always used tapered mortise and tenons for the leg joints. To make the leg tenons I've always made them on the lathe. To get a good fit it always took a few tries to get a perfect fit. I've been wanting to try the Lee Valley tenon cutter to speed production but the size I need seems to be always out of stock......so I made one today.
Similar to what is called a rounding plane for making dowels but I need it to make tapered tenons.
Most commonly a old plane iron is used for the cutter but I did not have one so I grabbed a piece of 1095 tool steel and made the cutter. When I milled the slots I made them .030 wider than the bolts to allow for adjustments.
Just like a pencil sharpener. Stupid mistake, I put the cutter on the wrong side so I have to turn the leg left to cut. They can be made to cut with the leg held in a vise but since all my legs are tapered and hard to clamp I turn the leg into the cutter.
The end result.
First try into a test mortise and with luck the fit was close. I tweaked it just a hair and got it perfect. I have lots of chairs to make and this should speed production.
Brad_bb
That looks sweet!  I like the use of Osage for the body too.  Good choice.  I'm inspired, and I'll think I'll make a similar dowel maker  with Osage.  I think I have an extra plane iron.
Ljohnsaw
Cool! But what do you use to make the tapered hole?
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Larry
For these chairs I drill a 5/8" hole than follow up with a 12 degree tapered reamer I bought from Lee Valley. The tenon cutter pictured cuts a 12 degree taper to match.
I also have 6 and 8 degree shop made reamers that I sometimes use.
Tom K
Great job on finding a home made solution to your problem!
Does anyone else wish they were Larry's neighbor? I'd stop over at least once a week to to see what cool stuff he was up to. ffsmiley
Old Greenhorn
I do, but I don't think he would tolerate me for long. I'd be over weekly asking if I could 'just run these dozen or so leg blanks through his tenon cutter?' and other such small things. ffcheesy
doc henderson
Tom, I am sure Larry knows the teach a man to fish parable, and he would quickly offer to help you make your own.   :wink_2: ffsmiley
Larry
I really enjoy shop visitors. I get questions like "why did ya do it thata way?" "why not this way?". We exchange ideas and thoughts. I think both parties are well rewarded with thoughtful conversation. ffsmiley
farmfromkansas
I was going to ask the same question as John Sawicky.
