Finally installed a Lubemizer
Started by dogbo2013, May 05, 2024, 07:20:46 AM
dogbo2013
After struggling with choosing the right lubricant for years, I finally upgraded my LT40 with a Lubemizer setup. Pine has always seemed to be the biggest offender and causes me the most issues with pitch build up. I have been able to deal with it using water and cotton picker spindle lube, but I would go through 1.5-2 tanks of lube a day. I have always hated the amount of water it put on the wood and mill, but it was the only thing that would effectively cut the pitch. Now I am running diesel only and using very little. It cuts the pitch with ease and I am using about 2.5 gallons for every 40 hours of cutting. Based on recommendations from others on this forum, I plugged the bottom hole on my guide block and only use the sprayer on the top of the blade.
GMB
That is a sorta expensive upgrade but worth every penny.  :thumbsup:
I mostly saw Pine but I have not made the switch to Diesel yet.  When I see any blade buildup, I switch to continuous for probably 5 seconds and then back to pulse.  My 5 gallon jug easily last a couple of weeks.
My mix is a glug (about 2 oz.) of original liquid Cascade per gallon of water.  I found that even the spindle lube that I was using made suds while mixing and Cascade does not.
ladylake
 Back when I was using soap and water I used the same as dogbo 1 1/2 or 2 jugs a day.  Good move switching to diesel, now you can honestly use a quart or 2 a day.  Steve
TimW
Quote from: Magicman on May 05, 2024, 07:40:32 AMThat is a sorta expensive upgrade but worth every penny.  :thumbsup:
Lynn,
       I use Dawn dish soap.  Works fine for me.  But it does make lots of suds upon mixing.  I'll try Cascade next fillup.
Get the Cascade in the light green jug.  I remove the white squirt cap so it will glug.DSCN0302
DSCN0306
One glug (about 2 oz) per gallon.
fluidpowerpro
I have had good luck using pine sol (or generic equal) that I get at the dollar store. It's cheap enough I can use it generously. I put it in after the water so it don't suds up.
Change is hard....
Local wind direction is determined by how I park my mill.
millingaire
This seems to be the ingredients:
Name
Mixture
Product Identifier
64742-58-1
% (w/w)
Lubricating Oils, petroleum, hydrotreated
spent
40-60%
Petroleum distillates, hydrotreated  heavy
napththenic
64742-52-5
20-40%
4-Nonylphenol branched, ethoxylated (>1 - 9% in a non hazardous diluent)
127087-87-0
<1%
*The specific chemical identity and/or exact percentage of composition have been withheld as a trade secret within the meaning of
the OSHA Hazard Communication Standard [29 CFR 1910.1200].
*More than one of the ranges of concentration prescribed by Controlled Products Regulations has been used where necessary, due to
varying composition.
Full text of H-phrases: see section 16
For the price of spindle oil, I think diesel is much cheaper, and it too is a distillate. So, 25 bucks vs 100 bucks, and they are both petrol.
booman
Make sure whatever you use doesn't contain chlorine bleach which can cause corrosion or rust.
2019 LT15G25WIDE, 2013 LT35HDG25, Stihl MS880 with 59" bar with Alaskan sawmill attachment.  John Deere 5045 tractor with forks, bucket and grapple.  Many chainsaws.
