Marking Pens ? Probably a stupid question
Started by Murphy625, April 24, 2025, 09:27:06 AM
Murphy625
I'm cutting logs and need to mark the ends of them.   I don't want to guess or purchase the wrong type of marker for this.
What do the professionals use to mark the cut ends with?  Is there a specific brand or type of marker everyone generally uses?
I just need to write down about 5 digits.    Need something that isn't going to fade in the sun or be washed away by rain, and that writes on a chainsaw cut end.
Thank you
doc henderson
these are wax crayon type.  they also make holder that can go on a retractable lanyard.
Frickman
I have used wax lumber crayons, railroad chalk, and paint.  I purchase railroad chalk by the stick at my local hardware store.
Old Greenhorn
I use lumber crayons. They don't fade BUT the wood does and so readability will change over long periods. Get some different colors and see what works best for you. I use yellow on darker hardwoods and red on conifers, blue works well too. The crayon holder works nicely, but I also use a CH Hanson Pencil Pull, actually two. (I learned that trick from CustomSawyer) I have one on each of the rings on my suspenders. One has a carpenters pencil for shop work and figuring, the other has a crayon stub for marking logs. Both are very handy.
Murphy625
BargeMonkey
Crayons like everyone else mentioned, if your not doing a high volume. My normal log buyer has an attachment that goes on a spray can, makes legible 6-8" #'s and he's fast with it. Can see them clearly on a load I shipped in.
g_man
I use the crayons too. In the winter they get hard and don't write so well especially on wet wood but I can make them work but you have to look close. The scaler at the yard uses a special paint spray, red or blue, like Barge mentioned and that seems to work very good.
gg
I use DeWalt crayons in the Winter and Dixon in the Summer.  Temperature does make a difference.
Stephen1
I'm sawing some hardwoods now that I marked in the November with red crayon, I'm not liking that I can't see what # log it is. If I hit metal, which I do , I knock the price of the log off the next order. I buy my logs from an arborist and that's the deal we have. All my wood are yard trees.
I'd like to switch to paint for the next load. What kind of paint?
Riwaka
Developing high-end forest log marking for tracing log sources and tracking log supply chain security, log quality etc purposes. Beyond the bar codes and QR codes for individual logs stapled on and sometimes fall off.
Like the leather stamping tools.
From simple handheld log-end marking tools, to log-end hammer stamps for logs to log-end stamps that fit on processor heads (in developments)
Deeplai - Polish Company.
Youtube Deeplai - example with the adjustable log-end hammer stamp & handheld electronic device.
https://youtu.be/rTJKA9LzC9w?si=kfw_93RL20hiiatO
https://www.deeplai.com/technology/dms/    (manual marker stamps that work in a frame)
https://www.deeplai.com/technology/dma_s_a_automated/
The automated marker is designed for hard wood marking based on Dcode. The levels of hardness require a focused solution foreseeing the species specifics.
Figure out the above to be cheap enough for the woodlot level?
longtime lurker
Best thing I've found is a ballmarker. Designed to write on log ends, sawn lumber,  steel etc... with a range of colours that remain visible for years.
https://www.tigerpak.com.au/refillable-ball-marker.html
I don't know the north American equivalent sorry
Dave Shepard
I'd like to find a crayon holder that actually held on to the crayon.
Old Greenhorn
Dave, are you saying you can't find the holders like Doc showed above? Or are you saying you can't get those to grip the crayon well enough. I have had the latter problem too I put one wrap of electrical tape around the crayon in the grip section and that seems to do it pretty well. I have one of those I taped a cheapo HF tape measure to one and I pull the tape out and lock it at 'my measurement' then mark the log of slabs to my cut lengths. Works like a charm, been using it for several years now and replaced the tape once already. At $3.00 a pop, I build it into my overhead costs. ffcheesy ffcheesy
Refillable ball marker on Amazon
paint ballmarker
Dixon crayon holder with nut to tighten
lumber Crayon holder
Links might help..
Dave Shepard
I have a few of those wooden crayon holders. The crayon doesn't stay out.
doc henderson
I have them and they do better over time, and you do have to crank them down.  they are cute! I like old fashioned.
Quote from: Dave Shepard on May 05, 2025, 03:35:44 PMI have a few of those wooden crayon holders. The crayon doesn't stay out.
Doesn't "stay out" ?? what does that mean?  Or is "out" typo for "put" ?? Just curious.
Dave Shepard
The holder loses its grip on the crayon and it slips back in. Then I have to get a knife point to slide it back out.
Old Greenhorn
Yeah, I had that issue also, as I said, that one wrap of electrical tape did the trick for me.
maple flats
My experience with railroad chalk is that it marks very well, but washes off easily. I use it to mark for cutting rounds for firewood splitting. I have marked them and then a day of rain and the marks are gone. They won't last long with rain, I don't know without rain, I've only used them and had them wash off with just one day of gentle rain. So, I only mark what I plan to cut that day. While it wouldn't be ideal for marking the BF, I used to use marking paint with a Mingo marker, but I've found I like the rRR chalk better. Nice bold, broad mark, but short lived.
I have had customers use livestock marking paint and marking sticks.
Not lumber marking here, but I use school board chalk held by a chalk holder, but the thing is the kid's stuff is a little thinner than the teacher's chalk so the holder is a little big inside. I wrap a round of masking tape around the chalk, it's just enough to grip. I use it to mark metal, mostly stove pipe, so I can line up the screw holes when putting pipe back together. Nothing more frustrating as fighting with stove pipe to line the screw holes back up after you have taken it apart to clean.  :veryangry:
